ASAP spring assist issues
I've got an ASAP knife that never did open with authority. I was trimming German Bearded Iris tops for replanting yesterday with it. I felt I got sand or dirt in it because it went from a poor opening spring assist to no opening. I took it apart and cleaned it out. Now, it's back to being a poor opening spring assist. Upon opening the knife, the spring assist system appears over engineered and underpowered with the dual coil assembly. I hope Buck has something in the works to correct this weak Spring assist design. Anybody have any advice on getting a 294 to open better I'm even considering removing the springs altogether and just running it as a manual.
.......... Anybody have any advice on getting a 294 to open better.....
The BUCK Forever Warranty
We warranty each and every Buck knife to be free of defects in material and workmanship for the life of the knife, and we will repair or replace with a new Buck knife, at our option, any Buck knife that is defective. Buck Knives does not warrant its products against normal wear, misuse, or product modifications. Buck Knives are not intended to be used as hammers, chisels, pry bars or screwdrivers. If your knife was damaged due to misuse, our repair department can analyze the damage and repair it for a reasonable fee. If your knife is unable to be repaired, we will extend a one- time courtesy offer, allowing you the option to purchase a new knife for 50% off of our MSRP price listed on the website, excluding any custom knives or web specials.
Been wondering, do the ASAP knives stay closed in the event of an assist spring failure? I hated the way Kershaw handled a lot of their AO knives.
There is a lock, you can manipulate it with the same finger you open with.
What DeSotoSky said. Mine opens with authority right out of the box.
This got me thinking maybe it was a little off out of the box. It opened about the same as when new so didn't know any better. I took it apart again and made sure the bottom spring was engaging properly with the blade put it back together and now it opens better than it ever has. I suspect I didn't get the bottom spring in right when I cleaned it but to be honest it must of been that way from the factory because it now does open with a bit of authority which it has never done before. It used to open all the way but just barely now it's working great. Very happy now I was getting a little down on a knife I like a lot.
The ASAP knives at least my Momentum has a blade lock on the spine of the knife that sticks out past the scales it's a little different lock but works fine it does take a little getting used to especially when new it was a bit stiff but I don't mind it now.
