ASH LE edge
Hi there, first post as I just received my first Busse knife. Wanted one since I first stumbled across the Busse website last year and finally found the knife I wanted, here in the UK... A mint ASH LE!
I love it but I was expecting it to be a bit sharper, especially from the belly to the tip it is quite dull and it hasn't been used or sharpened in any way... YET!
What I want to know is what type of edge does it have, and what sharpening tips or edge modification would you all recommend?
Thanks JJB
just hit it against a rock a few times. It will sharpen right up.:)
I was just going through how to sharpen an ash also(deciding what way to go.
I ended up keeping with flat stones.
It is now very very very sharp with minimal work.
The way I look at it is it is much easier to go from a v-grind to a convex grind then making it convex and wanting it back to a flat grind.
Not sure you would want to go back once it is convexed but....
I would just get it sharp to start.
Other will have much more info for you and most likely suggest sandpaper and something to cushion underneath.
good luck.
