Assessory pouch question.
kyhunt
Basic Member
The assessory pouch shown for the 5 and 6 will it fit the 4 sheath? Does it have anyway to attach to a regular belt if you wanted to use it as a stand alone small kit?
No (and yes) the mounting holes towards the tip of the blade do not line up, but you'll find many pictures of one mounted anyways. I've got one mounted to a "3", search function is your friend (saying this because the pics are priceless).
No (and yes) there are no loops or straps on the back of it, it's clean except for the mounting holes/eyelets. So you can run it with "tek-loks" attached with screws and it will mount to a belt just fine.
Going back and forth will be a real p.i.t.a though, once you mount it either way you'll have to remove screws to change anything. If you'll be using this as a "stand alone" kit I'd recommend you check out the countycomm set-up, which won't really attach to a knife but attaches easily to kit (loops, belts etc.)
Merry Christmas!
