I'll start out by saying I'm not an engineer. That being said........
For most automatic knives, the spring
IS under load when in the "closed" position.......and
NOT under load when in the "open" position. For these knives, storing for any lengthened period of time would be ideal in the "open" position.
I don't recall if SOG's "assisted technology" has the spring under load when closed. My "educated" guess (recollecting my understanding of the "coil" spring system) is that it is
NOT under load when closed...thus, storing it opened/closed makes no difference.
Perspective (this is my own opinion): Regardless of this, I ask myself what the maximum age is of my automatic/assisted knives? 3 years....5 years....10 years...a little more (certainly not "dramatically" more)? Unless it's a top-end manufactured or a custom-made knife, it's likely to be between 5-10 years under moderate (+/-) use: you might end of losing it before it reaches its "twilight years." So, whatever "passive" wear that happens which is obviously measurable to a spring in this scenario will likely match or exceed its average life expectancy. In other words, at least more me, this topic is likely a "non-issue." If you have this type of knife as a "collectors" knife, play it safe and store it open, blade covered, oiled, and in a safe/secure climate-controlled location.
I'd certainly welcome being corrected.
I store all my knives in this category in the "closed" position and have had zero problems with springs.
I hope this helps.
