 - Nov 11, 2011
Hey Guys - thanks so much for your help here.  Maybe not perfect but this is much better by far than ever before:
What I did was to heat the blades red hot with a propane torch and then use my same setup as in the other picture but with a four pound hammer. I was even able to strike the stamp four times on each knife. Before when the steel was cold I would hit the stamp once but then it would jump a little and I could never hit it again without getting overlapping letters. I considered an eight pound hammer but that was too heavy for my skinny wrist. Anyway I am happy with the results and owe you all many thanks.
Please help/advise!
I almost never get my name evenly stamped on a blade. My name is Kelley and what I generally end up with is "Kell" or perhaps "lley" and so on. I am using a name stamp from Infinity Stamps which is supposed to be for steel, with a holder for the stamp and also a machined steel block to lay the blade on. I use a 3# dead blow hammer. Obviously I am either striking the stamp unevenly or not holding the stamp straight on the blade but I cannot figure out how to fix the problem. Here's a pic of my setup:
Maybe what I have is not the right tool for the job? (There's about $150 worth of stuff in the picture not counting the hammer so I'd hate to replace it all but....if I need to...). Is there some sort of jig which would hold the stamp better?
Hopefully some of you guys can tell me what I am doing wrong or what I need to do better or (even) what better tool it might be wise to get.
Thanks so much.
Please help/advise!
Thanks so much.
