I stop looking when its gone.
I inspect for and expect one at virtually every step. Might not find one but it is a possibility right to the finish.
What's your usual practice on burrs in your end-to-end sharpening process? When you get to apexing, do you do multiple passes same side and intentionally form a burr, or do you keep alternating sides trying to avoid/minimize burr creation? I'm hearing folks recommend differing approaches on this, similar to stropping, so it gets somewhat confusing and trying to harmonize what seems like the most logical approach to go with when you're at a level of basic/proficient freehand sharpening, but not advanced.
I tried this and it did not work. DMI get rid of the burr with a short, edge-leading stroke -- generally about an eighth of an inch. If the stroke is longer, you'll chop off the burr, but recreate it on the other side, what people call chasing the burr. But you're not really chasing the burr, you're recreating it. You can test this for youself.
I can't say that I've ever experimented with "clarity/cripsness of the burr" versus whether you only stroke the abrasive in the spine-to-edge direction (versus scrubbing, or just edge-to-spine), but if any of you are woodworkers and have ever sharpened a card scraper (where you INTENTIONALLY create a burr with a burnishing tool), you always and only move the burnishing tool in the "spine to edge" direction. And in the case of a card scraper, there is no apex (you create a burr on one side of a squared edge). The point being, an apex is definitely not a requirement for a burr; you just need an edge (and even a 90 degree edge works).
Anyway, from the card scraper example I'd conclude that burr formation should be more effective if you only stroke the abrasive in the spine-to-edge direction. Of course, my card scraper analogy could be a poor one, relative to a knife edge.
In terms of metallurgy, I suspect (but I'm not certain) that certain alloys will "smear" more easily and therefore a burr is easier to obtain and feel, while maybe some alloys are more brittle and maybe a burr forms but it breaks off at the slightest touch.
It (burr formation) may even have some relation to the heat from the friction of the abrasive (again I'm not sure; just floating the possibility), so for example if you do multiple fast strokes with the abrasive, the heat from friction would be higher and maybe burr formation is more likely. At the other extreme, if you do very slow strokes, with time between each one where heat from friction doesn't build up, maybe burr formation is more challenging?
(...)In my view, burrs are a product of ductility. The more ductile the steel, the more it will be prone to burring (all other things being equal). This is why high hardness steels tend to be very forgiving of burr formation, while some stainless will be drawn out considerably by the abrasive.
