Atlas Mini Forge review and first blade results
I purchased the Atlas Mini Forge and I'll tell you my first impressions. To begin with, I am a novice at forging so I don't have any comparison stories. For a newbie though, nothing could have been easier. I took it out of the box, installed the burner and the propane tank and fired it up. It worked the first time.
It heats up quick and achieves adequate temperatures for forging blades. Make no mistake, when they say Mini they aren't kidding. I make small blades so it is perfect for me. If there was a place to give it stars I would give it 5.
Stacy, thank you for the plentiful advice. I got some scrap and pounded steel every direction to get a feel for the hammers and moving hot and cold steel.
Here is the result of my first forged blade. It is 52100, I started with a 1/4 by 5 inch piece. The handle is bead blasted G-10. I'm pretty happy with it although I'm sure I'll refine the process as time goes by.
Stacy. When you said not to worry if I catch the floor on fire I laughed, I have a concrete floor. But when I dropped the first hot piece, and 8 years worth of lacquer dust caught fire........How did you know?
........How did you know? .....
Been there - Done that!
Glad you like the Atlas. A review from a novice is a good review, because we with larger forges look at it differently. I agree it is a great entry level forge that will get use in the shop for years after a large forge is built/bought.
I think a lot of folks will be really excited when Charles finished the design and testing on his new medium size forge.
I will tell you folks a few things about the Atlas Forge that some know but most don't:
Five years ago, Charles ( creator of The Atlas Forge) was a new member and excited...as are most all newbies. He emailed me and others, and posted about questions and ideas. Seven months later, he came to Ashokan as a brand new maker ( I think he had made one knife) and was hanging on the outer edge of all the circles of old pros. He listened to what they said and must have realized that almost every discussion had some reference to the forge. He went home and started making himself a small two-brick forge. It was like most...rather primitive and ugly :) He was most disappointed with using a plumbers torch as the heat source. He researched many torches and ended up with one that was suitable. Then he addressed all the shortcomings of the wired up bricks. A few generations later he had made a home brew forge that was a 2BF with a little extra style and a commercial torch that would attach to a propane bottle. He modified it and improved it. He then took a good look at the torch and realized why old makers don't use one...it is a poor heat source. He designed a simple no-nonsense venturi burner. He has modified it to make improvements and made a larger version. Once the design was sufficient, he bit the bullet and ordered materials, parts, and contracted out laser cutting...and started Atlas Forge Co. He has continued to add improvements to his design, and probably will add more things as the idea grows. This is the real American Dream story...if you dream it, and work hard at it...it can succeed.
Amen to the American dream. Only in this country can you have an idea and the resources are available to make your dream happen. This is my third American dream and I love watching it unfold.
Thanks for the review. I'm sure others will find it very helpful in their decision making process.
Pretty accurate Stacy. I want to extend my apologies to anyone that purchased an early forge with the commercial torch. Despite doubling the BTU output, it just isn't sufficient. If you did purchase an early model, contact me and I'll make it right.
Are there any videos of the mini forge being used? I saw the videos of the newer prototype, but haven't seen any of the mini forge.
Nice looking razor by the way, razormaker!
Have any if you guys done forge welding or San mai with your atlas mini? I've only done general forging and heat treating with mine but I'm thinking about trying to make some San mai...
I made two billets of 1095/15n20 san-mai and one billet of AEB-L/1084 san-mai last year in one. Both 1095/15n20 welded great, although the AEB-L crumbled a little because of my inexperience. All three were no-flux welds. Borax eats these bricks like pancakes. I haven't personally tried kerosene yet, but am told that it works great and doesn't harm the bricks.
I'm almost done with the 1095/15n20 and will post pics of it soon.
Last weekend multiple billets of 1095/15n20 damascus were welded in an Atlas at the Knifedogs hammer-in. It easily gets to the 2350°+ range.
I sent you a PM. I have one of your older models.
