4 s ter said:The C70 ATR was included in a list of "knife designs geared toward MBC use" in the 2004 catalog (the last catalog to mention the MBC Program.
Also included in the 2004 list of knife designs "geared toward MBC use" were the Delica and Endura trainers, Chinook II, Gunting and Gunting trainer, Lil' Temp, Kerambit, Yohimbo, Temperance trainer, and Ronin. (I don't know why the Delica, Endura, and Temperance knives were not included in the list - just the trainers).
David
Kublai said:I'm aware that an MBC rating is primarily based on lock strength. Which is why I asked in the first place since the compression lock usually out-performs the liner lock. But after your posts I remembered Sal posting that frame-locks (integral) actually failed before standard sandwich construction liner locks.
Kublai said:So I wonder why the current list on their web site has been modified? Maybe at the time, research and testing for MBC rating was not fully developed or standardized, hence the phrase "geared towards MBC" as opposed to "MBC rated."
smcfalls13 said:MBC rated only refers to the lock strength. Not all of the knives have it advertised as such because calling it MBC rated could give someone the perception that it's designed as a weapon.
MBC or Very Heavy Duty means it's lock takes up to 200 lbs or pressure per inch of blade before failing.
peacefuljeffrey said:I prefer to carry knives that are not marketed, named, or otherwise overtly identified as "weapon" knives, combat knives, etc. I think that courts legal trouble if it should have to be used defensively.
peacefuljeffrey said:Now, as far as MBC, you mention failure pressure, but I ask is there no consideration for security, i.e. inadvertent lock disengagement during use?
I would rather use a dull kitchen knife than a spyderfly for MBC.smcfalls13 said:Though why the Spyderfly is with the MBC knives is beyond me...![]()
