If anyone can help me with this problem I sure would appreciate it. I have been making knives for a pretty long while, but mostly with 440C. I have currently made about 75 or so knives with ATS-34 and love the blades, but have recently begun having problems with the finish of the blades when putting on the final polish. I am getting some serious pitting on some blades. I heat treat at 1920 for 25 minutes, temper 3X @ 450 and it leaves me with a Rc of 59.5. After H.T., I take it on down with 120 grit, 220, 400, 600 and then polish. It is only when I get to, oh, the 600 grit stage do I start seeing the pitting in the blade. Naturally, they do not buff out. This has got me sick, as these were my Christmas knives for customers. What might be going wrong??? This does not happen in each blade, just about one fourth of them in each batch.
I have noticed some interesting things when finishing the ATS 34 blades and wonder what is going on....#1) The steel rusts like crazy when I am grinding on down from 120-600. I will be grinding a batch of 12 blades or so, at the time and grind all at 120, then all at 220, etc...by the time I finish a particular grit with all 12 blades, they will all be covered in surface rust. Go to the next grit and it grinds off, naturally, but it will rust again before I get to that blade again with the next grit. This NEVER happened with 440C for me...makes me wonder what is going on here...#2) I have noticed that the ATS34 is much much harder to work than 440C....it is harder on belts and you dang sure better have all your scratches out before you go down to the next grit, as there is NO polishing it out later on....I could get away with that with 440C, not ATS34! Am I imagining things?
Any comments/suggestions are sincerely appreciated. I am just a hobby knifemaker, making a hundred or so knives a year. I am not a full time maker like most of you guys. Sure do appreciate any help you can offer.
Thanks,
Hank H.
Thanks,
Hank H.
