Attaching a lanyard
How does one attach a lanyard to a ZT200, do you just use one hole or go through both holes?
I use a thin piece of wire to pull the lanyard loop through the lanyard hole on the knife
Then pull the knotted section of the lanyard through the lanyard loop and tighten
Without looking at the knife I'd run the lanyard through both sides of the handle. There is always a chance that there might be a sharp edge on the inner part of your handle that would wear away at the lanyard if you only use one side. Also the knife will swing straight when held by the lanyard going through both sides of the handle. You could try it both ways and see if you like one over the other.
