I just recently purchased through a private seller a CQT Magnum folder made by TOPS. The knife was originally purchased in December of 2000 and having never been used is still in mint condition. However, since this is the only CQT Magnum I have ever held and examined I need some reference from other Magnum owners regarding the liner lock mechanism.
1.) When the knife opens the end of the liner lock closest to the pivot protrudes about 1.5mm outside of the frame. Once the blade is in place I am then able to press the edge of the liner back up into the frame. Is this a normal function of this knife? It doesn't seem normal, it seems loose but if this is how the knife functions then so be it.
2.) The liner lock is attached to the frame at the rear of the lock by only three screws. It seems to me that if there were a second screw placed midway in the liner this would alleviate the subtle up/down movement of the liner. Could those of you with later model Magnums take a look at your knife and tell me if the liner attachment has ever been modified?
I'm probably going to send the knife into TOPS for inspection and possible repair but I wanted to get some feedback from other owners first just in case the knife is performing normally.
Thanks.
Thanks.
