shunsui
- Aug 12, 2008
Was down at Tad Gear the other day and they had these by the checkout counter like bubble gum.
This isn't just a standard ferrocerium rod, the Aurora has some Magnesium built in like the misch metal ferro rods. When you strike them, you get a little burning ball of Magnesium/misch metal intead of just a spark.
This is the built in striker blade held in place with a screw.
This is a shot looking down the tube. You can see at the bottom that the screw which holds the striker blade in place goes all the way through into the tube. This kind of kills the whole point of a waterproof tube as you would probably get some leakage here.
You can see there's ample space at the end of the tube for the screw hole to be drilled without penetrating the storage cavity if enough metal was left at the end of the tube.
You could probably pour a little silicon glue or epoxy down there and seal it up tight.
The machine cuts around the striker blade are very sharp. I thought about smoothing them out but for now I just slipped this old vinyl cap on the end to keep the sharp in and the dirt and water out.
I'm not too concerned about salt water getting in and reacting with the fire stick, but I like the idea of containing the stick so you don't get any accidental sparks from it banging around in your bug out bag or whatever.
edit: They come with black anodizing now and the striker blade is some tungsten, carbide, cobalt alloy now. Pics at TadGear.
They're available at
http://www.campingsurvival.com/aufistflstan.html
They're made by Solo Scientific
http://www.soloscientific.com/aurora-fire-starter1.html
