I'm pretty sure I could guess which blade is AUS-6, if it's anything like the AUS-6 used in my Spyderco knife. AUS-6 will be the one that chips, rolls, gets dull quickly, and has the tip break clean off under the slightest pressure. If it's serrated, like my Spyderco is, the serrations will break clean off just from allowing the edge to contact the table while slicing deer sausage.
On the other hand, if you think a weapon used to defend your life should be more than the bare minimum quality, there are plenty of much better options out there. For instance, ATS-34 and 154CM are not really affected by bone, and will barely be dulled from moderate force thrusts that even strike concrete.
Otherwise, I still have to agree that steel type should be about the last thing to worry over, behind important things like training, awareness, edge geometry, etc.
