hmm, that's interesting!
I've never quite heard that about soft versus hard steel. However, I must admit, my edc is a SOG with Aus-8 and it does very very well. I know it's not a tough steel, but it's really easy to sharpen and man I can get a serious edge on it.
But I've got to think that the soft vs hard steel is talking about bending and denting compared to brittle. A real hard brittle blade like on a chisel can chip or break if dropped where a softer metal will flex a bit.
But I think overall a hard blade will hold a better edge over time as long as you're not using for chopping wood or sword fighting.
Some Japanese swords are made out of the famous San Mai III steel. It's a layered softer steel wrapped around a very hard steel to produce a very hard sharp edge but some overall flex and bend to the blade when being struck against another blade.
I have been waiting for a thread comparing these. I have been favoring my ontarion RAT 1 over my spyderco tenacious lately. Rat 1 is AUS8 and Spyder is 8Cr13MoV.
My RAT has held up better than the Tenacious.
I dont know much about knives, but I have heard that hard steels can perform worse that soft steels sometimes. The soft steels will hold an edge while the hard steels disintigrate with use because it they are more brittle. -I have never tested that, just something I heard that I thought made sense for some steels.
I don't wanna be a smartass, but I'd like to explain some things in terms of edge retention and different steels. First of all, there are no hard or soft steels. Different steels have different potentials for hardness that can be reached during heattreatment, but quite often manufactureres do not make full use of these potentials. Some companies run 8Cr13MoV at 60 Rc, some only at 58 so the differentiation between hard and soft doesn't really work here.
Secondly, whenever a steel is called 'brittle' (i.e. it's lacking toughness), it doesn't necessarily have to do something with the hardness. For example a S7 steel hardened to 59-60 Rc will be tougher than S90V hardened to 57-58 Rc. It depends on the composition of the steel, though that's not the bottom line. It's not as simple as I would like it to be.
Finally, edge retention depends on large parts on the content of carbides in a steel not on the hardness. S90V has a lot of very hard vanadium carbides which contribute to the superior edge retention of S90V. So again, the composition of a steel makes the difference.
But everything that I mentioned is not worth considering if the heatreatment process is all messed up and does not make full use of the steel's potentials.
I hope that what I've written makes a little sense and helps to understand the performance of certain steels a little better. Now, btt: As long as Myerco does a good HT on both steels, I assume it will be difficult for anyone to tell them apart.
They are the same stuff. Some makers (Spyderco comes to mind) run the HT a bit high on the steel (both AUS-8 and 8Cr13MoV) to get more of an edge out of it. Brings it a bit closer to 154CM performance, and a bit past 440C. Less stainless though.
As tested by whom?
Spyderco has said 8Cr13MoV has similar edge retention to AUS8.
My own testing says the same.
Whose test data have you seen that says that 8Cr13MoV outperformed 440C in edge retention?
Thanks guys for all the info and opinions about the differences. On a knife that sells online for $35.00 is a $6.00 difference between the AUS8 version and the 8cr13 version going to really show a difference in blade abilities?
