Following on from an earlier thread, thoughts on this one guys: http://www.hardcorehardware.com.au/weapons/mfe01.php
Again this one is made from D2........
Developed in conjunction with the IRR, our MFE01 "Rhino" is designed to perform a multitude of applications dependant on situational requirements. Engineered for the extreme end of Hardcore use in MOE/entrenching roles, the MFE01 is the perfect compact all-round utility tool.
The claw at the business end of things is specifically designed for maximum leverage and also incorporates a modified cutting head designed primarily for splitting. At the end of the handle we have a chisel/pry that can be used for typical mid-range field duties. The MFE01 is skeletonized to mitigate weight with medium sized lanyard holes at both ends for the attachment of a carabineer or rope lanyard.
Some of the tasks we expect you'll use our MFE01 for include: prying, digging, chopping, hammering, cutting, smashing rock, as a climbing aid, for defeating locks, smashing windows & windscreens and raking out their frames and as a load bearing device.
The MFE01 is constructed from D2 tool steel, has a robust black Teflon coating and G10 handle. Our G10 grip scales are available in coyote & black and are secured with Torx screw, all steel fittings.
Not really sure why they call it Rhino tool (doesn't say on their new site) or who the IRR are???
Cheers
Jontan888
(It's an asian thing)
Cheers
Jontan888
