I've been reading up on different hardening treatment methods and the one that really intrigues me is Austempering; mainly because it was recently discovered. From most of the articles/books that I've read, the typical quench medium is a salt bath. That seems to be widely used but unless you can afford the equipment for it, it doesn't seem very feasible for home DIYers.
What I am really interested in knowing is, could liquid metals be used instead of a salt bath? For example, tin-lead (~63% tin %weight, ~37% lead %weight - eutectic composition) (basically solder material for electronics although they use 60/40) melts at 183 °C (around 361 °F). That is below the martensite start temperature (assume 400 °F) which would allow one to easily see if the temperature is too low (solid bits start to appear). There are also many low temperature liquid metals; it's just tin-lead seems to be the cheapest and easiest to work with.
From what I've learned from my Heat Transfers courses, metals have thermal conductivities that are typically higher than their convection coefficients when in liquid form (convection depends on buoyant forces and metals aren't very good at that). Due to this property, the bulk thermal transfer during a quench should be conduction which simplifies the process as preheating to achieve a certain viscosity is not needed. Also, since most metals don't typically boil below 1000 °C, one would not need to worry about any vapor jackets.
What do you guys think? Has anyone tried this before? I know that molten lead is used in some cases to soak steel at the austenizing temperature so it definitely wouldn't be damaging to steel. I can't find any articles on whether or not tin would damage iron but there doesn't seem to be a reason why it would.
Side note:
Currently, I'm finishing up profiling a sword from O1 tool steel by hand. I'm going to give Austempering (aiming for 100% bainite) a try for the following reasons:
1) Quenching and tempering have been done for 3000 years or more. It just doesn't seem that exciting now that we have a very good understanding of what goes on during the hardening process.
2) Running a molten solder bath so far (at least on paper) seems safer than running a salt bath. Correct me if I'm mistaken but the salts used are sodium and potassium nitrate? Those are powerful oxidizers and without the proper equipment, I don't feel safe using them. I'm also not going to purchase any equipment as I don't foresee myself making more than a blades a year.
3) As stated above, I'm almost done my sword which is made from O1. Since O1 is not as tough as something like 5160. I figured that it would be best to maximize toughness and sacrifice a bit of hardness. This tradeoff seems worth it to me.
Thoughts or comments on this would be nice!
Side note:
