- Jul 12, 2008
Haven't been out for some months as I've got a kid at the end of July.
Here I'd like to share a recipe of autumn candy made by chestnut.
It's called 栗の渋皮煮 in Japanese. It's nothing more than rather primitive candy
but can serve as a food storage method as well.
I make them at this time of year and eat them little by little, spending a whole year.
A very good menu with either coffee or tea, sometimes with whiskey :thumbup:
First, peel off outer most shell with your favorite blade.
As it is quite smooth and hard, sharper edge is better without no doubt,
although I never worry about it as far as WSS forum is concerned.
You have to be **very careful** not to break inner brown peel.
If you break the inner peel, even a slightest scratch, then the chestnut will break
in the following steps and it will never be a nice candy.
peeling done. this took about 2 hours. maybe this is the most demanding step.
You may put your finger at the bottom of the blade to process chestnuts.
This is a very useful position with great control in many kinds of choir.
As you may see, the blade side face of the bolster is inclined
so as to get into this position easily, as well as the bottom of the blade can
be cleaned with ease. Also please note the boundary of the blade bevel and
the ricasso is shaped to smooth surface to make cleaning easy and avoid stress.
To be added, you may see the soldering of bolster is very poorly done
Then put them into Sodium bicarbonate (baking soda) solution for a night.
the solution density maybe 10g/1000ml or so.
Boil it with baking soda solution with small fire for about half an hour.
The solution gets dark brown with excess tannin.
After boiling, remove fiber and threads from the surface of chestnuts.
Then change water (this time, without baking soda) and boil it another half an hour.
Check if annoying fiber or thread remains on the chestnuts.
They should look like this.
After cleaning, dump water and measure the weight of chestnuts.
Add sugar of 70% weight of the chestnuts, with water comes somewhat above
the height of chestnuts.
Put drop-lid into the pot. (about drop-lid please look at http://en.wikipedia.org/wiki/Otoshi_buta)
Boil it until the liquid obtains some viscosity and liquid level goes well beneath the
top of chestnuts.
Almost done. Put them into sterilized bottles and store them at cool dark place.
Thanks you for looking and reading.
top of chestnuts.
