- Mar 30, 2014
how do I cure fresh cut black locust for making a handle for a battle ax that I will use in reenactments of viking raids
Allow it to dry out (cure) slowly. Some folks paint the ends with wax or paint to impede the differential drying process
I want to experiment with a small "drying box" using incandescent bulbs for low dry heat but have not quite yet. Guess I better hurry before the bulbs are outlawed![]()
This is a lot of trouble for a mere piece of wood. It is true though that you can't be in a hurry.Go to the pet store and buy a ceramic reptile warmer. They screw right into a light socket. They come in different wattages, though they will run way more than an incandescent bulb for cost.
Years back Browning Arms was accused of stocking their guns with "saltwood" which caused metals to rust prematurely. Apparently their inventory of walnut was subjected to a curing process that was accelerated by salt which attracts water (ie lowers the humidity). The salt was always kept well separate from the wood but I guess some of it vapourized. There are other less corrosive desiccants available these days.Excellent information. I'm trying to cure a piece of vine maple for a handle experiment and I think I'll try the wax on the ends. Humidity is relatively high in my area year round unless it drops below freezing. My main worry is if it's two damp it'll start to rot. I have a warm, dry attic, a less warm but still pretty dry shop (I manage to keep it around 40% humidity in there) and the rafters of my woodshed as storage options while it cures. Do any of these jump out as excellent/ horrible ideas?
