AXE/ HACHET and KNIFE Quotes
"I would rather leave the house in the morning without my pants then without a hatchet and a pocket knife".
Bernie Weisgerber
(Of course without pants I would have no easy way to carry the hatchet and the pocket knife ! )
What are your favorite sayings ?
“Here’s Johnny!” - The Shining (1980), Jack Torrance (J.Nicholson)
"Penetrative power is not the sole requisite of a felling axe; for if the edge be too thin, it will be found much easier to drive it into the wood than to pull it out again; for this reason, narrow felling axes are left with a thick obtuse edge, so as to avoid penetrating too deep into the wood. A narrow axe may cut a larger section of wood than a broad one the cutting edges being equally thick; that is, the fall of a narrow axe may more than make up in depth of cut what it wants in breadth of a broader one. But it seems a waste of power to force the obtuse edge of a narrow axe through the wood, when the same power would make a broader one, with a more acute cutting edge, penetrate equally far, and thus cut a larger section. It would appear, then, that as deep cutting can be avoided by adding either to the breadth or the thickness of the edge; and that as the broad edge will cut a larger section than the thick one, that the edge ought be as thin as consistent with strength, and sufficiently broad to prevent it sticking in the wood; so that the conclusion arrived at in this case is, that the American or broad shaped felling axe ought to yield a greater quantity of work than the long felling axe, with the same amount of labour."
~Daniel Doull, The Manipulation of Wood and the Forms of Edge Tools Used Therein, The Irish Industrial Magazine - Volume 1 - Page 477, 1866
I'd sure hate the term "Fan Boy" to ever be accurately aplied to me, but when it comes to OG gunwriter Francis Sell theres realy no other term for it, and oddly enough I'm not even embarased about it... his advice on hunting knives, pretty much just as astute as his advice on everything else to do with hunting:
"Nearly all work is done with the portion near the tip, but rarely the actual point. Select a knife with this in mind and you will be well served." Francis Sell.
