the-accumulator
- Jan 24, 2008
Hanging a no-name faller's axe has been a bit frustrating, or, rather, let me say educational.
My goal was to use only wood wedges to rehang this 3 1/2 lb head on the 28 inch haft (on which it was loosely hung when I acquired it). After disassembly, I reshaped the haft to accept the head mounted snuggly further down on the shoulder than before. There was a significant gap left from the metal wedge (that had been installed in the previous hang), so I employed a cross wedge to fill the void and tighten things up. I used Swell-Lock and trimmed the haft a bit proud of the top of the head. It looked real pretty and felt great, but, unfortunately, promptly worked loose as soon as I put it to task.
So, I added a barrel wedge and crossed my fingers, but this didn't solve the problem. Adding the second barrel wedge gave me reason for hope, and on my first test run produced no signs of loosening. The second time I swung it, however, a tiny gap less than the thickness of my fingernail appeared where the haft met the head at the bit side of the eye. I have since applied several treatments of BLO where the head and haft make contact.
How concerned should I be? Should I just keep using it and see if it gets worse? I think it's rather ugly right now and might look better it i trimmed it flush, but I believe the haft mushrooming out of the top of the head can only help to hold the head on. Any thoughts? T-A
