Axe / Hatchet ?
What's the difference between an Axe and a Hatchet ?
I know the obvious reply would be the size but I have seen Axe's that are much smaller than products that have been labeled Hatchets !
Also I have seen Tomahawks that resemble axe's Does the length of the Haft in relation to the size of the head have anything to do with which catagory they fit into ?
Sorry if it seems a dumb question !!!!
Just found this which to me indicates that a definition is still a little vague !
"Hatchets tend to be small hafted axes often with a hammer on the back side ( the poll)."
I am not so sure that there IS a definite answer to the question. To me, a hatchet is a small axe with the end opposite the blade being flat like a hammer.
it is supposed to go by haft to head ratio, but with modern marketing this has been set to the wayside
that's a tough one, brother. good question.
i think most folks don't really know, but (to me) the thing that really differentiates an axe from a hatchet is the head geometry, which is moderated by two factors predominantly;
an axe head can be very specialized in cross section, and i think that is a good practice the more i chop with one - since they are heavy comparitively, it stands to reason that you are going to be doing something more-specialized with the axe on large scales, while the specialized things that you might be doing with a hatchet will be small scale (carving, for example - Ishi loved to shape his bows with his hatchet, for instance), in optimized and ideal settings at least. - that's lot of theory there in one sentence, isn't it.
hatchets will also prevalently be straight-bit'd, which can be nice if you care to try carving with them.
these are just my opinions on the matter, definitely not gospel.
nothing better than a good carving hatchet, except maybe a good adze.
summary.
1) an axe can be almost anything in cross-section, as it is optimized for specific types of tasks, while a true hatchet will tend to be wedge-like in cross-section, so that it can split fairly well, while still being a decent chopper and limber by virtue of its light weight assisting its poor cross-sectional geometry, when compared to its big brother, a proper axe.
2) an axe tends to have a more-curved bit, while a hatchet will often have a larger radiussed bit to perhaps something completely straight-edged.
...so essentially, a hatchet tends to vary by its edge geometry and remain a hatchet, while a fine axe tends to vary in its cross-sectional geometry, while remaining true to its respective speciality; large, fast work.
man, i didn't realize what a complete chopper geek i was until today.
hatchets are great basecamp tools.
HTH.
vec
I... I... I thought I knew, until you asked the question. I could always point at something and say "that's a hatchet," or "that's an axe." Now I'm not so sure, so I'll be following this thread to find out.
This is from Wikipedia:
A hatchet (from the French hachette, diminutive form of French hache, 'axe') is a single-handed striking tool with a sharp blade used to cut and split wood. Hatchets may also be used for hewing when making flattened surfaces on logs; when the hatchet head is optimized for this purpose it is called a broadaxe.
Hatchets are taxonomically differentiated from hand axes by some using one or more of the following characteristics: the addition of a hammer head and a head 1–3 pounds (500 to 1,500 grams) in weight.[citation needed]
Hatchets have a variety of uses, such as tasks normally done by a pocket knife when one is not present. The hatchet can also be used to create a fire through sparks and friction.
Yeah I figured I knew as well, LOL !
Let's not even get on the subject of when does a knife become a machete and when does a Machete become a sword !!!!:D
Say, pit, when does a knife become... oh, never mind.
i may have to try this screwing up:p
come on over any time, brother, i'll teach ya all ya need to know. - just ask my Erica.... :D:thumbup:
any chance you might be making your own heads in the future?
yeah, i will probably get around a forge one of these days and knock out a hundred or so heads. i am starving for a chance to pound steel again anyways.
any chance to screw around while ostensibly working is a good thing IMHO. :D:thumbup:
the ECO hawk is the first and smallest of some other heads i designed that TOPS wants to make with me, ...so just as good for the end-users as me doing 100% on my own maybe, for those who aren't too sentimental at least....
God Bless TOPS. - them and the Bucks sure are decent people IME.
i'll probably ask some smiths to make me some groups of ten or so heads too, until i can do it myself again.
there is a growing community of good hawk smiths.
the brother i used to hammer with passed on, R.I.P., so no local forge for me any longer....
vec
I really don't know what "a good adze" is Vec. I wan't to say I am an adze hole, but I don't know if that would be accurate yet or not.
the central africans have a lot of good adzes that i have seen, much like proper tomahawks, but with a wonky bit.
vec
I read somewhere that the difference between the two is simply that the hatchet, being smaller, could be used with one hand and with the axe you need to use two hands.
This is getting to weird for me. I hope ya'll decide what the differences are! I'm of no use here!
