Axes for building log cabins??
Hi folks,
I'm looking for advice on some good axes to build log cabins. I have 2 small trappers cabins to rebuild on my trapline and would like to build them the same way my grandfather did when he ran the trapline. The only axes i have looked at so far are the Gransfors axes. I know i would need a feller axe and a broad axe and possibly a buck saw.. Any help or suggestions, advice are welcome.:D
a broad axe from gransfor is pretty expensive - maybe more than you want to spend. i'd recommend looking on E bay - most of them go for upwards of a hundred bucks, some more. but occasionally you can snag one in good condition for less than fifty.
you might want to check out http://www.amazon.com/Axe-Wielders-Handbook-Michael-Beaudry/dp/0882907115 - he covers a very basic intro to building a cabin with half-dovetail joints - i'm sure there are better books that go into more detail
besides a felling axe, broad axe, and buck saw you are probably going to need a chisel too and a square of course
I don't see the need for a broad axe unless you are going to square up your logs. If you are, then consider adding an adze too.
If you want to see some good examples of log-notching and cabin building, the Foxfire series of books (volume 1) has some good examples of it, done by the local old-timers the old time way.
Book
Book
Blue Sky is right, no need for fancy stuff for round logs, but if you want to make square logs, you will need a broad axe and an adze and a froe. Actually, I don't know a thing about building. I just like to play with my tools. For real advice, see the Forest Service manual, "An Ax to Grind." I found a link to it from somebody on this site. It has 30-some pages of more solid historical and and how-to info than the rest of us could come up with in this millenium. Thanks to whoever posted that link. I am forever in your debt. And again, Blue Sky's advice about Foxfire books is as solid as the Rock of Gibraltar.
