FK said:
My comfort position to hold a working knife is with thumb on one side slab and forefinger on opposite side slab.
A slight slip rearward while holding the knife will unlock the axis bolt.
Stab and pull back,,,,,, the knife will easily unlock the axis bolt.
My preference is the frame lock Sebenza type design.
'course, the majority of framelocks are susceptible to accidental unlocking when torqued counterclockwise (if it's a righty knife). Try it yourself; imagine the blade got stuck, you're torquing it out, and perhaps you're a bit sweaty and your hand slips a little. Once your fingers slip, they tend to catch the lock. This is a reasonably well-known issue, though we hope it's enough of a corner case that it's not a big deal. Just like, for most people, pulling back on the axis lock buttons appears to be a remote corner case.
But with the axis lock, if you're really worried about hitting the buttons by accident, 10 minutes with a stone and you can grind them flush. Okay, now it's a little more difficult to close, but let's face it, the axis lock appears to be
the most reliable lock out there today, and with just this small modification, can be made to be as bulletproof as I believe we can expect from any man-made lock. Although I'm beginning to think now that the compression lock seems to be as reliable as anything out there, and there's no lock buttons to worry about.
Spin whack test is only one small test of real world conditions.
Well, I'd say it's one
important test, not a small one. But strongly agree that there are plenty of other tests, including (but not limited to) torquing, white knuckling, palm pressure on blade spine, etc.
Joe
