Not to sound harsh but I fail to see the logic in not buying an Axis because you fear the springs may break.
The reasons for feeling this way....
Liner locks and frame locks are also springs. They will eventually wear at the engagement pont and move further across the tang until they have no place left to go, then blade play is introduced. Once this happens the knife needs to have the entire lock side scale replaced or a larger stop pin put in (which runs the risk of throwing off the geometry of the knife). Both fixes are things you should not do yourself.
Lock backs can also wear and eventually need serviced, but this is less common (probably about as often as an Omega spring breaking!).
My point is that any folder can be analyzed for wear points that would require warranty work, I think the risks are greater for that need with a liner lock than an Axis lock. I have personally owned at least 4 liner/frame locks that wore out and would engage all the way across the tang, I have never had an Omega spring break.
I think at one point BM had a small batch that were probably not heat treated right and came out a little brittle because there was a period where 2 or 3 people mentioned broken springs, but I have not heard of a breakage in quite a long time.
Buy one, they're sweet.
