- Jun 8, 2014
How safe is bm's axis lock? I just got a custom griptilian, and there's the slightest amount of side to side play and was wondering if it's normal & safe.
Side-side play is a factor of how tight the pivot screw and frame screws are. On my Rift, I have all of the side-side play removed, partly by tightening the scale/liner screws securing the stop pin. This enables me to keep the pivot a little looser and still have a solid blade. Just use a T6 torx driver for the small screws and a T8 for the pivot screw.How safe is bm's axis lock? I just got a custom griptilian, and there's the slightest amount of side to side play and was wondering if it's normal & safe.
The Custom Griptilian is just a regular production Grip that you get to choose handle color and blade steel. It's not "custom" like you're thinking of a custom knife maker, or even a Gold Class Benchmade. The "custom" is because it's a bit of a build-your-knife process. Other than that, it's still a production knife. Side-side play in an Axis lock is nothing to sweat about. Just adjust the pivot screw and frame screws.The Axis is a good lock, one of the best.
If the knife has blade play out of the box I'd send it back. Blade play on a custom-anything isn't acceptable.
You can try tweaking it out but many times it's just a sign of problems down the road.
