If you are oversea, BM will likely mail you the springs.
is that an assumptions or has it happened before?
I learned that the notch that goes into the hole in the liner had to be bent a bit sideways to prevent it from popping out when the spring is tightened.
Mine have been going strong for a couple years. I also sent a pair to KennyB but don't know how they are doing. I would assume OK. I used what I had on hand in the right diameter which was steel MIG welding wire. It can rust but from Florida humidity and the occasional washing, I don't see rust on the little bit of the springs I can see. Maybe a little surface rust but it would take salt water to rust all the way through I would think. I got some stainless MIG wire from a friend if I ever need to make another. You can also buy stainless fishing leader material in all different diameters if worried about rust.
So they actually broke? People have guessed that omega springs break because of the material they are made from. I guess that isn't the case because the wire I used seemed quite different than what the stock springs were made from. I'm a little surprised as a spring should last a long time as long as it's not going through plastic deformation, which omega springs shouldn't be from the small distance the lock bar travels.
I find that interesting since I had a 710 that I bought back in 1999. I sold it in 2010 to fund a different knife and never did have to replace the springs.Yeah, I remember you sent me three pairs. I think I've gone through two since then, but I had a bad habit of flipping--they seem to last longer than the factory ones though.
