See the thing is I'm confused on how the burner exactly works? Is it just basically a controlled system that burns the incoming propane gas as to maintain psi?
The burner consists of several parts. You have the fuel injection system, which is a gas jet that generally uses a welding tip to supply gas at a given psi. This generally goes in the back, aligned with the very center of the pipe nipple. You have your intake, which is an opening where air is supplied. This is also normally in the back(the opening located further back than the tip of the gas jet), with the air either being forced into the burner via a fan, or being sucked into the system by the low pressure created by the gas rushing through the pipe nipple. You then generally have some sort of reducer bell at the end, which is put on backwards. it looks like this: ====C. This causes the gas to slow down as the pressure is reduced, which inturn allows for all the air and gas to mix properly, causing a good burn. Find the proper size for this reducer bell will make the difference in a venturi burner, and is still useful on a forced air burner.
I'm sure that google has plenty of pictures of burners that you can check out to see what I'm refering too.
Also how does the layering of insulation work, i.e. Forge casing, than insulation, fire bricks, and over that ITC/Satanite? I'm sort of sketchy on that.The layering of insulation isn't terribly hard once you figure out what each thing does. The shell itself is generally not overly important on most forges to the overrall value of the insulation. All you are trying to do is make a practical body to hold the insulation in place. To be practical, it needs to stand up too several hundred degrees of heat comfortably (heat will escabe to the shell of even the best forges generally). This is why metal, ceramics and clays, and refractory cement all work well as forge bodies. The next layer is the basic insulation, such as kaowool, durablanket etc. These are blankets made of ceramic fiber, which works to insulate things with both the air inbetween the fibers, and the ceramic fibers themselves. It's like a down feather blanket for your forge, except far more effective. Be sure to use a respirator or something when handling it, because it's just like fiberglass for your lungs. The next thing that is used is either satinite or itc-100. These improve the insulation value by refracting the heat around the forge. I believe that itc-100 is something like 90% effective at this, with satinite being a little less effective. This means that your forge will heat up faster (less heat aborbed into the body), and that it will run more efficently. It also serves to seal the ceramic blanket, keeping the nasty little fibers from getting to your lungs. The firebrick works simply by taking up space. Think it in terms of chocolate milk. You need to make a cup of chocolate milk, but the pitcher is full of milk, so you have to use more syrup to get it to the right flavor. By taking up space with refractory material, you are effectivly reducing the ammount of milk in the pitcher. Less energy is used to heat a smaller volume, so more energy can be used to get it hotter. It also keeps you from tearing your durablanket up, protects against flux, and works as a nice shelf for the metal in the forge.
