Back in time....longhunter's knife & sheath
Most of the frontier sheath work I do is based on the time period of 1830-1870 and of the Rocky Mtn west, this time I went back to the 1760-1770 era east of the Mississippi......
The knife is by Mike Mann of Idaho Knifeworks - the blade is based on the knife excavated at Ft. Ticonderoga, NY - the grip is elk antler and the fittings are iron....
The sheath liner is double thickness elk rawhide with a braintan buckskin piece sewn into place at the inside top. The cover is braintan buckskin dyed with walnut hull dye. The sash flap is a piece of buffalo rawhide. All sewing was done with linen or hemp thread or real elk sinew. The beads are antique 8/0 pound beads.
The style and porcupine quillwork decoration is based on a couple of existing original 18th sheaths. The quills were dyed with natural dyes: the black/brown quills were dyed with a mix of walnut hulls and ground charcoal, the red with red ocher, and the yellow with rabbit brush, a local southwest member of the sunflower family. The cone tinklers are handmade brass with buffalo hair tufts. They are attached with linen cord through copper and antique glass pound beads.
Not too shabby even if I do say so myself :D - especially considering this is the first real quillwork I've done in 25+ years.........
Hope ya'll enjoy the look see
Absolutely breathtaking. A real work of art. I particuarly love the quil work. The use of the natural dyes is outstanding. A museum piece for sure.
Truly a beautiful combination. I love the obvious balance on that knife, too!
(Somebody's gonna get mad at me some day, but why are there always knives in the "Shop Talk - BladeSmith Questions and Answers" when they should be put in the gallery?)
Beautiful work, congratulations! I always enjoy pictures of original or reproduction knives from the Colonial period.
Thanks Guys - I've been stuck in the shop working so I've been slow getting back........
Here's a sort of step-by-step photo layout of the sheath in progress:
I did it as much as possible using only the methods and materials that would have been available at the time.
Step 1) - After doing the research (IMO an important step to get it "right") I always do a sketch to put my thoughts/ideas into some semblance of order - with quill and/or beadwork I usually work out a color scheme as well. This is only a general idea at this time - as you'll see the design wasn't "written in stone" - the whole thing will often change and/or be adapted as I go along.
Step 2) The sheath liner is double thickness elk rawhide - in this case I doubled the liner since one thickness wasn't stiff enough for the size blade. The inner liner is a standard wrap around pouch sheath with a welt sewn into place along the cutting edge using well waxed/rosined linen thread. It also has a piece of braintan buckskin sewn in at the top as liner for the handle and to which the outside braintan cover will be sewn - something I do to make it a "neater" package and to give it a bit more "grip" on the handle.
Rawhide must be worked wet, but not too wet, something only working with it will you learn - it's a bit of a hassle, but well worth the effort. Once the liner was sewn I protected the blade and ferrule from the moisture and then clamped a couple of boards over the blade until the liner was almost dry. I then took the boards off and let it dry completely. Clamping it between the boards isn't absolutely necessary - but if you don't use them you need to keep a close eye on it as it dries so that it doesn't warp - let it air dry only! Once the inner liner was dry I sealed it with varnish - I use my own home made traditional linseed oil & rosin based varnish - other period type sealers that can be used are spar varnish or a thin coat or two of hide glue. Then I sewed a second piece of rawhide over the first - I whip stitched it along the outer edge and let it air dry with the knife still in the sheath to maintain the form. Once dry I sealed this piece as well.
In the back ground are most of the materials I planned on using: at the top is a hunk of elk sinew for sewing (I also used linen and hemp thread since the sinew I had on hand wasn't teh best quality and didn't make enough good thread as I wanted), the porcupine quills and antique pound beads (about 8/0 size), and the brain tan buckskin dyed with walnut hull dye - the bottom portion almost black for the cuff and the rest a lighter color.
3) Here is the cuff (at top), cover, and sash flap (made of buffalo rawhide) all quilled and beaded. The beads on the cuff and sash flap are attached with sinew - on the far left are a couple of sinew threads. Serendipitously the sinew on the back side of the flap makes it sort of rough/sticky which will help with retention on the wool sash. With this style sheath the body of the sheath is worn under the sash with the falp on the outside. The quills and beads on the cover were sewn on using hemp thread.
For info on how-to bead and quill, a good starting place is www.nativetech.org, This along with several books available will teach you waht you need to know. There are several techniques for both beading and quillwork and my advice is to study as many sources as possible and then practice, practice, practice.....
When you compare this picture to the original sketch, you can see I changed both the overall pattern and quill colors somewhat. The pattern changed since the sheath wound up being wider than originally sketched (a not unusual circumstance) and the colors changed since I didn't get the natural dyed green/blue I wanted.
The dyes used for the quills were: walnut and charcoal for the brown/black, red ocher for the red, and rabbit brush flowers (a member of the sunflower family) for the yellow. I did try using indigo, a fairly common commercial dye of the period available either in it's raw form or from boiling trade blankets dyed with it, but the quills came out so dark that they looked like the black/brown so I decided to just use the three natural dyes. To dye the quills I steeped them in hot, but not boiling water mixed with the dyes for a couple of hours.
4 & 5) Here are front and back views of the cover and sash flap sewn onto the liner - the cover is sewn along the edge with a double whip stitch - a whip stitch was the stitch most commonly used by the Indians - I like to use a double stitch as it gives a nice look, but also makes it stronger and longer lasting since with the whip stitch the threads are exposed to wear - although in this case the beaded edge helps protect the thread from wear. Additional decoration is two hand made brass cones stuffed with buffalo hair. They are attached to the sheath with linen thread running through some larger antique pound beads and a couple of old copper beads. The buckskin cover is sealed with a mixture of bear oil, beeswax, and pine rosin, which also helps protect the quills.
Thanks so much for showing your methods Chuck. I have no idea how to make period sheaths. I finally bought your DVD and watched it 3 times. Its great.
