Depends on the knife, depends on your hands... depends on a lot of things.
I've met some folks with big, meaty hands, that press the lever in on a lockback when they grip it tightly. I've also met some people who sit and play with their linerlocks, snapping em open until the stop pin is deformed, or the blade dented just enough that the whole thing doesn't lock up so tightly anymore. Granted, it can be repaired, probably under warranty, too, but it can be a hassle.
From what I've heard, the compression lock on the vesuvius... (I think it's on the gunting too???) is supposed to be much stronger. For myself, I haven't had the time to go physically look at one, and I haven't found a very good explanation online of how it works, so I can't really say either way.
Some knives lock up with massive power... some fold under pressure. A quality lockback will normally outperform a cheaply done linerlock, and vice-versa.
For myself, if I had to choose a locking technique, I'd have to go with a quality butterfly knife. When it's open, it's open, and when it's closed, it's closed. And when open, it's held solidly in place by two pivot pins, and the tang pin, which provides a third holding point. BUT, that really only works for the good ones... cheapies have cheap, press-together pins that break. Quality, as I said for the other lock styles, is as much a determining factor as the design. Granted, spyderco doesn't have a balisong (YET... heh heh heh... can't wait), but there are others out there that might suffice until they do.
My advice... go look at the knife you want to buy, and get the feel of it. Grip the lockbacks, to see if you press em in, work the liners, to make sure it's comfortable to you.
