Backpack set
I am building a backpack for hiking and as a survival tool if hard times happen. I am in the McAllister OK area which is very green with rolling hills full of trees and lots of game.
I want suggestions on knives and firearms for my bag that may be used on hard times.
I need two knives, a chopping tool, and two guns.
Knife choices.......
Pocket Knife
1. Ontario Rat 1 in AUS8.
2, Qieen Cuttlery Large Stockman in D2.
3, Other (your choice)
Belt knife
1. ESEE 6 in 1095
2. Falkniven F1 in laminated V10
3. Other (your choice)
Chopper Tool
1. Large knife such as BK9, Marine Raider, other large chopper.
2. Simple quality hatchet
3. Quality boys axe size axe.
Side arm
1. Glock 20 in 10mm
2. Ruger Blackhawk in 45lc
Long gun
1. AR15 in 300 Blackout
2. Mossberg 500 in 12ga
3. Ruger Scout rifle in ,308
4. Ruger 10/22
5. Other (your choice)
Bonus....... What saw would you pack?
I would go with the rat 1. It would handle smaller tasks and would be able to sharpen easier in the field. The esee 6 would handle larger tasks and small chopping. Then a camp axe for main chopping. I would take a Glock 21 and an ar-10.
Ummm, based on most of your choices, I think you need to do some more research and personal testing. I'm not trying to be rude (though I may be so), but many of your choices are VERY subpar. I don't claim to be the GREAT guru of this subject, but I do have extremely extensive experience in this area. If I have not insulted you, and you wish to talk further, PM me. I wish you the best in your search but am concerned that you may actually apply some of these ideas into a real and dangerous scenario. Wishing you the best. :thumbsup:
I'd go with a good hatchet or boys axe over a large knife.
Vintage is the least cost for the highest quality, but council tools makes pretty good stuff.
You could also get a Vaughn riggers axe so you've got an actual hammer for use when needed.
Rat 1 (I believe you can get one in D2)
ESEE 6
Small axe
Glock (I would choose 9mm or .45 due to availability)
Last one is tough. Probably the 10/22 Takedown with 4x Leupold. Threaded w/suppressor.
1.Large sebenza 21
2.carothers field knife/or a carothers hdfk
3.Carothers light chopper/ or a fiskars x25/x27 axe
4. Smith and wesson 460 magnum
5.10 22 magnum breakdown
6. Silky saw
Thank you for the reply. What would you consider a good set up?
OK, here goes: Pocket knife, something more robust e.g. Cold Steel code4 or a quality canoe (depends on your style preference). Belt knife, you're OK (maybe check out EKA also). BK9:thumbsup:, Junglass, custom :thumbsup::thumbsup:. Sidearm, Ruger Super Blackhawk .44 mag (will handle a WIDE range of loads, from lower power 44 specials to cor bon penetrator 44 mag (305 gr. 1300 fps) ) :D I went with the non-fluted cylinder and round trigger guard. Long gun, I would need more info on your desired purpose (you list a WIDE range) :confused:, but a Mossberg 590 would certainly handle almost any situation without looking too extreme (AR-15) to those you may run into (especially law enforcement). Saw, any good quality folding saw (don't go too cheap). That's my .02; remember, you got what you paid for. :p
When it comes to walking, pounds count, ounces count more. Set your total pack limit to 25% of your body weight, and then get out and practice. Sure extra heavy blades mean you can make shelters, but shelter making is not quiet, and the results are not easily concealed to someone looking for you. If you are hiking, then half your gear weight being fire-power is useless, unless you are on land in which you are actually going to shoot stuff on.
As you put miles on and build both fitness and experience, you'll lighten the load in some ways, but then also be able to comfortably carry a heavier load. My list right now would be:
LM Wave
LT Wright next gen
silky pocket-boy
the lightest bolt action single shot .22LR that fits well.
That's assuming a living off the land scenario.
Normal hiking and true "run for the hills" SHTF are pretty much incompatible in my book. You won't be able to practice the skills for the latter while doing the former for enjoyment, so why bother. Want to build a bug-out rig and take combat training classes, groovy. Want to get out and enjoy some fresh air? drop a SAK in your pocket, grab a water bottle and hit the trail.
I suggest you first start with the ten essentials. Just google "ten essentials".
Per another's recommendation, I'll state carrying a pack at 25% of your weight is a heavy pack. Seek a lighter load. A fixed blade knife is last on my list. Due to weight for purpose I carry a GEC paring knife when carrying a fixed blade on the hiking trail. I never carry a chopper or firearm on the hiking trail (I hike in the eastern USA). Neither are worth the weight.
