hello!
i am new to busse combat knives but the design is just striking - so i need to have one. but i can not decide which one.
hopefully someone can help me.
generaly i am looking for a ever-day-user as i do not like buying expensive knives and not using them. it is not primary the look but the performance what makes me buying them.
all clear so far but now here comes the problem: i do outdoor stuff thus i need a knife for general outdoor purposes like bushcraft and hiking but the most time i use/carry a knive is not outdoors but on academic work/normal city life and at home that makes me using a knife mostly for food preperation or similar every-day tasks. no way - i would like to start a fire, building shelter, making triggers for traps and similar as every-day tasks but unfortunally my life is different
and such things could only be done in time off.
thus i need to conceal my knives so i have to carry them mostly in a shoulder holster or IWB that includes larger knives too as i a am a tall man. if the knive is deep enough IWB that the handle does not push into my stomach it is realy comfortable - only pulling the knife out makes people look
to make things short (i hope the introduction is not that confusing) - i am looking "kinda" for kitchen performance that means cutting f.e. buttering bread, cutting hard sausage (i do not know if you in the US now that?) bread, bacon, even pizza
, esp. buttering bread and stuff like that. than typical every-day tasks opening packages, cutting wire and so on. but then there is bushcraft/hiking part too. which of the bigger ones would be good for some finer work too like carving triggers for traps or whittling
i hope i do not bore you because this is not the end
i what to improve performance of the knives. i do not need a edge which a big angle so i want to convex the secondary bevel all the way through to have a zero edge grind (i hope i expressed well on this point because my knife english is not that well).
which one would take that zero edge grind at best?
and which has a primary bevel on the complete height of the blade?
which one would after being improved cut in terms of the tasks described above at the best? i mean size (and weight) matters for cutting pizza or bread which one would you recommend? that the BAD is the best slicer should be clear.
i mean to be realistic - i think i end up buying two a larger and a smaller one. but first it is a question of which one i buy at first
and second i mostly will only carry one knife so the smaller should be able to do still a litte bushcraft and the bigger should be a good slicer too.
thank you for reading that far. know my question: which one shall i get? or should a take a bark river as all of them have a zero edge?
how does a busse perform compared to a bark river
i hope someone can help me
here are some questions the the models:
general:
-what is the height of the blades? i only know that the skinny ASH-1 is about 2" high which would make a great cutter if the primary bevel starts right at the top
-where does the primary bevel start (top of the blade, 3/4, middle?)
-which has a convex grind?
-has one a zero edge (convexed all the way through)?
-will there be other knives at 60-62 RC i am thinking for a Cultellus ?
Bagers: which one? i thought of the SHBA but how thick is the blade?
SAR5: how heavy is it?
SAR: will there be a SAR4 or SAR4.5?
ASH-1 can this knife butter a bread? the spearpoint looks awesome! but is it usefull on a blade 2" high?
Cultellus: what about this one? i forget to mention it
thanks four your patience
general:
