Bad-Dog Bowie
Dog....bone that is.
I have been wanting to do one like this for a few years now after seeing a similar Bowie in Bagwell's book.
This one has an 11" blade of cable damascus with a few 1/8" O1 drill rods mixed in. I did the cable a bit different this time. When I cut the cable it unwound itself, so to took all the individual sub-bundles and bound them together with wire....then added some drill rods. The press squares a messy bundle like this up in a hurry. It was drawn out and folded once. Couple little pinprick inclusions but not bad at all. The blade is 5/16" at the spine. the hamon, visible in a few of the pics was kind of a surprise. I fully quenched the blade and then after tempering, I torch drew the spine out to the tip with the edge in water.
The dogbone handle is osage orange with brass and steel fittings. The nameplate and pommel cover are recycled bandsaw blade. The guard is gun blued mild steel and the octogonal ferrule is collared onto the osage, made using a trick that Bagwell himself taught me.
I blade finished up incredibly sharp! I mean "skeer the heer" right off you arm sharp!
I am not sure about sheath yet....I thought about a wood sheath made from osage to match....but it will also get a Southern Comfort from Sastre.
Here are the pics:
Wow, now that's a stunner!
You can see the Bagwell influence but it definitely has your stamp on it.
Here is a pic of the sheath. It is cut from the same osage board that the handle was. The frog stud is cable damascus that I attached to a piece of drill rod and it uses a piece of banding material as a backing plate.
The throat of the sheath is lined with deer suede and it makes a friction fit to the blade.
Thats a really fine looking piece, it has blended purpose and function with classical styling and aesthetics - and that sheath really sets it off beautifully. Fantatsic work Greg.
Stephen
WOW !!!!!!!!
That is a very Great looking Bowie..
Tricks from Bagwell himself,that is great.
Great looking Damascus pattern also.Keep them coming.
Bruce
Damn Greg!! Email me your photo set up. The best images I had were with an overcast sky. Now that its sunny I cant get a good photo. Take a look at the companion post of today and you will see what I mean. Your knife just made me ask!!!
Those are beautiful.
Magnificent ! I like the view that acentuates how powerfully thick the blade is at the ricasso and thin at the edge. It really DOES look like the dogbone handle bowie that is on Bagwell's famous book. The burnt finish on the osage, gives it the final touch. Jason.
I handled this knife the other day. It looks much better in person :). Feels great too... Loved everything about it.
Matt
