Bad for my spydie?
I frequently use inertia openings to open my knives. The other day someone told me I shouldn't because it stresses the blade too much. I figure that it's no worse that flicking the blade open hardly with my thumb. So what do you think? Should I stop the inertia openings?
Snap openings or inertia open is not all that great for any knife. It has a tendency
to damage the opening stop pin or elongate the stop pin holes in the liner. It may also void any warranty.
It's probably more taxing for your knife than slow , deliberate openings.
That said, i have another question : since i am also a computer nut i overclocked every system i owned. That will shorten the lifespan of the cpu, but in a world that makes a cpu obsolete in 6 months it really is not a concern.C'mon, even if you don't plan to upgrade your pc every year , a cpu that lasts ,say , 5 years instead of 15 is not a big deal,is'n it ?.
I think the same thing applies to knife : if a knife is well made and has a good quality , it is probably built to outlast me , so if i shorten his lifespan a little by snap opening it , the chances i'll end with an unusable knife are very low compared to the chanches of loosing it ,damaging it in an accidental fall,etc.
Low quality knives have lots of problem dealing with inertia opening,high quality knives don't.
I'd like you to share your thoughts about this.
maxegb-
that's the way I think about it. Before I purchase a new knife I make sure it is of the utmost quality. All spydercos that I own have passed my tests of quality.
I have owned an Endura for over 5 years and when it was my daily carry piece I would snap open it almost every day. After all that time there was no unusual wear or tear and no blade play.
I didn't even know I was doing anything bad until someone told me so. But now I figure that if I have a good knife it should stand up to my quick wrists
I haven't messed up any of my knives doing this in all these years so I figure it can't be horrible but I still want other people's input.
Too much force for the intended purpose is the culprit. No more than necessary.
Too much force also takes its toll on the locking lever of a lockback.
sal
Whichever of the above theories you accept, you can conduct this experiment on your own folder:
- If it's a lockback, open it non-inertially and check the amount of play in the lock, both vertically and horizontally.
- If it's a liner lock, do the same test, but also make a note of how far across the tang the liner travels before it comes to rest in the locked position. Be sure to make these notes in writing and put them where you can find them, e.g., in your computer or Palm Pilot.
Now adopt the habit of opening the knife inertially each time you use it, making a note on your calendar to perform the above wear-tests every three months. Use this time wisely, to perfect your ability to draw and deploy your matter-separator safely in consistently short times.
If at any time you discover additional play in the lock, or additional sideways movement on a liner, discontinue interial opening except in emergencies, and figure that the slight wear it cost was paid off in terms of improved muscle memory and self-confidence. Keep the mechanism oiled and clean for minimum friction.
By stopping wear early in its course you will have retained the knife's safety characteristics while learning/perfecting a valuable skill that could save your or another's life. That skill can be maintained by a practice similar to the "dry-firing" used by shooters: a few times each week, practise all the motions of a rapid draw but stop short of the actual inertial "snap" of the blade. Concentrate on form and you will maintain or even improve speed.
Ken Delavigne
P.S. Certain models such as the Starmate and the current Military versions have designed-in compensation for liner-lock wear, but the actual adjustment is better done by Spyderco. This is a finite amount of adjustment, however, that eventually could be used up. The radiused or step-type ramps will keep the liner from travelling off the tang to the right, but they don't prevent wear.
[This message has been edited by KenDelavigne (edited 11-21-2000).]
Hello Ken!
This is OT ~ The Spydie book you wrote is AWESOME!! it ROCKS!!
Sam
have spydies
will travel...
AKTI Member #A001148
