- Aug 15, 2005
Greetings, I need some help from the Gurus.
I would like to switch my 1.5hp Bader BIII over to variable speed. I have been reading up on VFDs and it looks like the “2HP KBAC-27D controller (nema 4, closed) and a 2hp Leeson 56H motor (113026)” are the ticket, if you have a KMG grinder. I think that the KBAC-27D controller would work for me, but I don’t think the Leeson motor would fit my Bader.
I checked the motor on my Bader and it’s a Baldor model CL3513. It has a 56C frame, and a 5/8” diameter shaft that’s 1 7/8” long. The Leeson has a F56H frame. I have no idea if those frames are compatible, but since the numbers are different I’m assuming they’re not.
I checked Leeson’s website for a 2hp, 3 phase, 208-230/460 volt, TEFC motor but didn’t see any with the 56C frame.
Next I checked the Baldor site. I found a model VM3558 2hp, 3 phase, 208-230/460 volt, TEFC motor. It has the 56C frame, and the 5/8” diameter shaft that’s 1 7/8” long. I can purchase the Baldor motor from a place called Electric Motor Warehouse for $196.34. The KBAC-27D can apparently be had from State-Electric.com about $325.
I am fairly sure that this motor would fit my machine and would be comparable to the Leeson motor. However, I know next to nothing about any of this stuff. Therefore, I confess my ignorance and humbly ask all of you electrical/mechanical geniuses if the Baldor VM3558 motor would work with the KBAC-27D controller and, more importantly, if they would function properly on my Bader BIII? Thank you.
