Bader tracking wheel question
I need some help here before early Sunday morning!
My Bader BIII tracking wheel has become misshapen from use and I am losing tracking control. It has highs AND lows!
Please take a look at your BIII and tell me if it has a slight crown in the center.
I have a machinist friend who can crown it for me today if that is the case.
I just need some verification from a friendly knifemaker!
The Bader BIII tracking wheel is crowned. It has a pretty good-sized rise in the center, actually.
If you're loosing tracking control, my first suspicion would be a loose bolt where the tracking arm pivots against the frame of the grinder. It's a smallish shoulder bolt and these back out sometimes. When they get loose, your tracking can get funky.
Good Luck!
No, it's the tracking wheel. My machine's bolts are tight, mine are loose!
I've been runnin' this thing for 7 years - it's time for some wheel dressing! I just didn't remember what it looked like.
Thanks.
When you have your pulley trued, you might suggest this to your friend. Turn the o.d. between centers on a expandable arbor. This will keep the o.d. true to the i.d. Then when you mount it back on the machine it will run true. When I did mine, I left a 1/2" wide area in the center flat, as it was turned. I then turned a 1/2 degree taper on each end up to the 1/2" area in the center of the pulley. If you put too much of a crown on the pulley, the belt will pucker in the center. If a 1/2 degree isn't enough to suit you, you might try 3/4 degree. If your friend is a machinist he will understand what I have said. Good luck. Hope this helps.
Yep, it does have a very pronounced crown in the center. With a gradual slope to the edges.
Couple layers of masking tape around the center of the tracking wheel seems to help my Bader.
I understand it myself. We just went to 2 1/2 degrees from the edges to the center and it runs great. I have no complaints at the moment after finishing out two blades.
Thanks.
