Bag of Tricks
LOL :D I wish I had a DV Camcorder so I could hook it up to my IEEE, of course than I would need a website so I could put up some vids.
Describe them the best you can. I got this one where you hold it in the foward grip. Then you throw it sideways so it's rotating parallel to the ground. At the right point you bring your hand up and stop it rotating on the back of your hand in a table top. Not that impresive but I thought I'd share it.;)
Ok, I really suck at this but let's try:
Start by a basic horizontal but as that trick nears completion (in right hand) it starts moving around the back and it throws it across the back and comes up on the left side, since it is moving and rotating pretty fast it has to do a double rotation and then I catch it in my left hand in forward grip.
My other one MMTMatrix has seen (he has seen all my tricks) but I always have a problem explaining, I hold it in the open position (not locked) between my thumb and forefinger (hold with the side of my thumb) and I spin it and rotate it on a horizontal plane, it twists around and I catch it in the reverse grip, I do that again and catch it in the forward grip. I can also do this while locked open and I stall it on the back of my hand, then I pop it up using my knuckles and it spins and rotates more and I stall it again, Repeat until you get the desired effect ;)
Let me know if you don't understand and I'll try to get some vids (crappy vids but I'll see what I can do). :D
