I decided to do a little more work on the BK2 I posted a couple days ago showing the inside cut out and the butt removed. I squared out the inside and followed the contour of the bottom of the handle, removing another 1/10 oz bringing the total weight savings to 1 oz exactly. I had nice pictures of the stock and modified knives without handles on them, but I dropped that old camera and well, it is now in the trash because it was a floppy disk camera and the reader no longer reads the disk, which means the photos are gone. I'm too tired to take off the handles again and re-take those.
I did think you guys would find it interesting to see how far I changed the balance point with my little project.
It took a nice long time just to get them to balance. Yes, both knives are on the aluminum tubing.
See, I would not lie to you.
See how the tubing is visible through the front handle bolt hole on the knife on the left? Look
how far back the hole is on the right. If Toooj or someone could tell me with certainty, what
that divot is on the blade just south of the grind shoulder, I'd love to know. I'm thinking it was
a pulled test piece for heat treat and that is the Rockwell impression. It is not present on the
other BK2 and not on any other BK I've stripped. It his a hole with a slightly raised halo
effect around it that you can barely see in the photo. That would be consistent with something
being forced into the steel.
Just for comparison sake, the jimping is exactly in the same location on each knife. I mean line
for line. I did not plan that, but it just worked out that when I put the knives on top of each
other, everything lined up perfectly.
This shows how far forward the point is on the stock knife, accounting for the added weight it has to balance from the handle.
I added this one just because I thought it looked cool.
