- Mar 24, 2020
Hey guys so Im interested in the Manix. I was wondering how the ball bearing lock compares to Benchmade’s axis lock. Is it better? Worse?
I've had an Omega spring in my Benchmade Kulgera break after a few years of use. The spring tension is a lot weaker, but it will hold the blade. Unfortunately, I think it also places more pressure on the remaining spring. The other Omega spring broke within a week. The only reason I didn't send it back to Benchmade after the first spring broke was because I wanted to see how it would function with only a single spring.While I’ve never had an Omega spring break in any Benchmade I’ve ever owned, I guess if one did, I suppose that spring pressure on the Axis bar would be weaker and unevenly distributed to the side of the bar where the spring is still intact, which “might” make lockup less reliable.
I have about 25 Benchmades and a lot of experience with the axis lock.Hey guys so Im interested in the Manix. I was wondering how the ball bearing lock compares to Benchmade’s axis lock. Is it better? Worse?
Problems: 1st, the omega springs break, but only if they rub on the handle insides. If it doesn’t rub in your knife, the springs will never break. After using a Benchmade a while, you take it apart and look for wear on the springs. That will tell you if they will ever break. G10 handle models tend to be the worst. They can be fixed by hogging out a little with a Dremel where they rub on the springs.
Take one apart. The omega springs reside outside the liners and inside the scales. If they touch the scales, they wear slightly each time they are flexed and will eventually break.They come with steel liners so what has the G10 to do with it?
