Balsa is firmer than leather, and compounds can embed very well into it. The extra firmness helps minimize rounding the edge, if pressure is a little heavier. Most leather, unless it's very hard or very thin on a hard backing, will tend to form itself around the edge of the blade drawn across it, which is more likely to round off or dull the edge. The ability of compound to embed into the balsa will make the strop work faster, in terms of polishing. You'll notice this in how fast the surface of the strop blackens (with the metal coming off the blade).
Balsa strops are about the simplest to maintain. When they get excessively dirty, just sand it clean and re-apply compound. Done.
Balsa sounds excellent. Wonder why you don't hear more about people using balsa, given its effectiveness. Maybe just because they aren't aware of it? To me, balsa already sounds like a better option than leather.
How does newspaper compare with balsa? Nice thing about newspaper: always cheap, always available, zero maintenance (just toss when done).
What I meant by "poor man's stone" is the folowing. Suppose you had finished sharpening on a 1200 grit stone (Ansi rating). That is equivalent to about 5 microns.
What would you do next to improve sharpness, if money were no issue:
- sharpen with a 1500grit stone (equivalent of abou 3.5 microns) followed by stropping on leather
- strop on balsa using 3.5 micron compound, followedby stropping on leather
- strop on leather using 3.5 micron compound
Thanks again David! Of course I know the answer "it depends". But your explanation makes it quite clear.
The only thing that was not correct in my "presumed assumption" was that money did not matter. I have a Wicked Edge system and balsa strops are about §40 for this.
I think I'll go for stropping with diamond compound first with a grit size a bit higher (smaller micron size) than the stone I finsihed on. And then strop on plain leather. Does this sound sensible to you?
Balsa is firmer than leather, and compounds can embed very well into it. The extra firmness helps minimize rounding the edge, if pressure is a little heavier. Most leather, unless it's very hard or very thin on a hard backing, will tend to form itself around the edge of the blade drawn across it, which is more likely to round off or dull the edge. .
I think that most folks who make their own leather strops leave out one very important step in the production. Unless the leather has been properly 'cased' it will not be firm enough for a good quality strop. Most folks just take a good piece of leather that they bought and glue it to a backing. This is NOT the way to make a good strop!!! The leather needs to be cased first, wetted, then rolled hard with a good solid rolling pin of some sort to compress the leather, then allowed to dry before gluing to the base.
The results make a good leather strop.
Stitchawl
Thanks Stitch.
I still need to play around with that a bit.
