I keep reading these threads and I keep seeing comments that the balsa is more firm than the leather... And I'm getting pretty confused!
What kind of balsa are you using?!? In my mind, it's the blocks or sheets of balsa used for model making. But that stuff is MUCH softer than any leather strop should be! I can easily score that balsa with light pressure from a fingernail. I'd have to really bear down with a fingernail to do that to a good leather strop. What am I missing here? Are you using some special type of balsa?
I've seen several strops being sold in knife sharpening threads that were just plain cowhide glued to a fancy paddle. The leather wasn't treated in any special fashion, but that fancy paddle and block of compound certainly raised the prices. Is THAT what you are thinking of when you say that the leather will curl around the edge? Obviously, it will. Most of them don't use compressed leather. (Note that I say 'most,'... not all.) But just as obviously, those things shouldn't be called 'strops!' They are just soft substrates for compound. Might as well use a copy of National Geographic (which, by the way, works really well as a finishing strop due to the clay used to make the shiny coated pages!)
If you can press your blade down into your strop so that the leather is able to curl up over the edge, get/make a better strop! But first, please tell me about this extra firm balsa!
Stitchawl
Stitchawl
