STR
Since you didn't mention if you planned on cutting wood, metal or other material, I'm guessing you are looking for one that will do a little of everything.
For an all around cut anything saw the JET Horizontal/vertical is not a bad price. Usually sells for about $330 and is sold by so many places that there is probably one withing driving distance from your house. Here is a copy of a data clip on the saw:
Model JETHVBS56M
Horizontal/Vertical Bandsaw
1/2 hp, 1 phase, 115/230V motor.
3 blade speeds: 80, 120, 200 sfpm; blade size 1/2" x .025 x 64 1/2".
Vertical work table, rear wheels attached to stand, adjustable material stop.
Features ball bearing supported blade wheel, adjustable ball bearing guides, heat treated steel worm gear and bronze drive gear, automatic shut-off after cut, shelf built into stand.
PRICE $329.99
The biggest draw back to this saw is the narrow throat. When profiling blades from sheet, I many times have to cut one side of the blade then flip the sheet over to cut the other. But for the price it does ok.
If you are looking at wood/micarta/non-ferrous many of the smaller band saws will do if you aren't doing a large quantity of cuts or heavy material. The 14 in JET isn't too bad of a saw I just moved up from one two weeks ago. I have been told the newer ones are far supperior to the one I had that was 25 years old. I just purchased a Rykon 18" and I love it! It's only draw back is its 142" blade length. Not as common as most, but since I mail order most of my supplies this isn't much of a problem.
The more you forge the less you need the steel cutting capability.
Jim Arbuckle - Maker
