Bandsaw blade thickness/width
I'm going to be ordering some Lenox Diemaster blades and can't seem to find any info on what people prefer for thickness and width. I have the option of 1/4, 3/8, or 1/2 width and either .025 or .035 thickness in any of them. Any opinions?
Edited to add: This is for cutting out 1/8" O1 blanks
What kind of saw are you putting them on? I assume you're planning on cutting mostly blade steels with these?
Personally, I'd probably just go with the thicker of the two as it will resist kinking/breaking a bit more. As for the width, I use a horizontal/vertical saw, and it uses 1/2" if you want full DOC in horizontal mode. If it's just a vertical saw, I'd say it depends on how thick of material you plan on cutting. A 1/4" blade will give you tighter contours more easily, but it will also break and off track more easily in thicker material. I've always been able to cut what I need with a 1/2" wide blade without too much issue. Sometimes you have to be a little creative on tight curves, but I'd at least grab a 1/2". You can try the narrower blades if you want, but unless you're cutting relatively soft and a thin materials, I don't think you'll like them as much.
It's an old delta meant for wood but I changed the driven sheave out for a larger one to slow it down. Yes, it will be for cutting blade steel profiles. I think I'll sacrifice some maneuverability for resistance to breaking and go with the 1/2" x .035. Thank you both for the input!
This is a mantra for people who cut out knife blanks from bar and sheet stock:
Grind curved lines ..... cut straight lines. You will quickly ruin expensive saw blades by trying to cut more than a gentle curve.
