I would suggest you find out where your nearest SAW supply place is and ask them if they carry LENOX Diemaster 2 Bi-metal blades. It runs around .24 cents an inch generally depending on the width of the blade, I use 1/4" wide and 3/8" wide blades which run that price + a welding charge of maybe 6-7 bucks. I have been using a custom blade the local place around here welded for me for over a year now and i have made several hundred cuts of all types in A2 from 1/16" to 3/8" thick.
Lennox Diemaster II for profiling or Lennox Classic for heavier straight cuts. I use 18 wavy for everything from 1/16 to 1/4 inch stock with good results.
I buy from the place above because of great service. They bend over backwards for my business. You may save a buck or two elsewhere but stick with the Lennox blades
