I wrote to Johnny Stout and he was kind enough to share this information:
"Tom, good to hear from you. You can cut metal by the friction cutting method
using almost any saw that will run at 3000 fpm. The good thing about it is
that you can cut using your old worn out blades that will no longer cut on
slow speed. On fast speed, the blade actually melts through the steel, so
sharpness doesn't play a huge part. I even use my worn out 6 tooth wood
blades. They are thinner and will cut better than the metal blades, less
resistance.
If your saw will cut that fast, try it and let me know what you think.
Good luck."
Johnny also sent this:
"Tom, I hope I was some help. Just a word of caution when friction cutting. Be sure
and use eye protection and as much safety gear as possible. I've never had a blade
break but it could, and sure cause some damage.
Go ahead and pass along the information to the Forum if you'd like, just be sure to
include the safety information.
Keep in touch."
Maybe someone with a fast enough bandsaw can try it and report to the forum, I'd sure be interested.
As usual, proceed at your own risk...
ps. Thanks Johnny!
