Have a woodworking bandsaw that's too fast for steel? Wanna slow it down the right way? HERE'S HOW.
14" bandsaw $200
Motor and redux $54 shipped (thanks greedbay)
4 prong plug $15
4 prong outlet $6
7ft 10/4 600v electrical wire $16
pulley for 1" output shaft FREE (canned from old saw parts, cut down on lathe)
I got an import bandsaw end of last year with the intention of converting it to cut steel. I already have two VFD's for my other equipment, so the plan is to add a 4 prong 220v outlet to the side of my VFD box and put 4 prong plugs on the machines.
After measuring I can fit the new motor vertical, which works cause the tension adjusting mount slots are vertical too. All I have to do is make adapter plates cause I am sure the redux mount holes will not line up with the slots. Two sticks of 3/4" G11 (thanks Jatmat) and 4 holes is all it takes.
Remove old motor, remove pulley, chuck it up and start cutting on the lathe. I cut it so all that is left is the 2.5" pulley. Gonna bore it out to 1.000, drill the setscrew hole to 1/4", make new setscrew.
More pics later as I take em. Boy am I excited!!!!!
old motor setup
New motor and redux
14" bandsaw $200
4 prong plug $15
4 prong outlet $6
old motor setup
New motor and redux
