The blades that were included with the saw is 14tpi and the steel is about 4mm thick.Steel thickness, blade configuration/teeth count also matter.
"The minimum number of teeth a band saw blade should have in the material being cut is three. However, it's generally recommended to have between six and twelve teeth in the cut at all times.
The number of teeth per inch (TPI) on a band saw blade determines the tooth pitch. The TPI affects the cut quality and speed."
4mm = .157"The blades that were included with the saw is 14tpi and the steel is about 4mm thick.
