- Aug 16, 2011
So I did my first barbeque of season this Saturday, a 9 pound pork butt. Smoked it for a good 11 hours and it came out pretty good. A little dry though.
Anyways I usually remove the skin from the pork butt, clean most of the fat off, apply some dry rub and then put the skin back on since it adds a little insulation from the fire. I used my little HI JKM for skinning since it's a small super sharp blade with a fat belly and no pointy tip. It did the job much faster than the Old Hickory skinner I usually use. Partially because it's so sharp but also because it's so compact and well balanced which made it very maneuverable. The fat tiny handle made the grip very comfortable too.
After the meat was done cooking we decided to slice it up rather than shred it. Rather than whipping out a carving knife I decided to stick with JKM even though it's waaaaaay too short for the job. But since the tip ofthe knife is basically a flat edge, I was able to stick the blade in tip first and saw/slice through the meat like butter.
Overall I'm very impressed with this tiny little knife. At first I didn't like it because I thought it was too heavy for a small knife and too short for a heavy duty knife. But it's heft and thickness and fat belly make it much more useable than a thin pointy mora of the same length.
One last impressive feature: after carving the pork butt I forgot to clean it when I was done. The fat and meat dried and stuck to the blade and I had to scrub it off with a scotch pad. When I was done the body of the blade was covered with swirly scratch marks but the edge was still as shiny as a mirror. I take that to mean the edge was harder steel than the body. I can't believe they bothered to put a differential temper on this little thing, but I guess they did!
