- Jun 4, 2010
Hello all, this one was at Andy's request - a closer look at the Bark River black compound. On a Washboard applied to paper he described it as making scratch pattern close (visually) to a DMT fine at 25 micron. Am not sure what it looks like on paper over a flat surface, or on a leather strop (probably considerably less defined), but it appears to be a range from 10u to 30u with most falling in the 15-22 range. There are fines that are much smaller, but do not appear to compose a large percentage of the total by volume.
I've noted before that the effect from various compounds seems to be very heavily influenced by the binder as well as the rated grit of the material. I don't have much more than a fat pinch of the compound to do any testing, but typically the Washboard tends to get a lot of penetration from a given abrasive when used with paper at moderate amounts of pressure. Used with less pressure, multiple sheets of paper, on leather etc would probably appear a quarter or less than the actual, in line with how most stropping surfaces effect the scratch pattern at a given grit.
The abrasive appears very much to be white AlumOx as it is somewhat translucent. My own opinion is this is about where a compound leaves off and one would be better served with a fixed abrasive if using anything more coarse.
