Bark River Gunny - Rampless - Review.
Background:
I have owned two Rampless Gunny's. I sold one, well, because I was stupid - and then had to wait to find a good deal on another come up - which had a ramp, I sent it in to be ground off and get a Spa treatment - an then got it back. I always thought I had written a review on this blade - but must have overlooked something! Doom on me! Here was my first Olive Drab Gunny (which I still think is one of the coolest colored knives I have ever had, in a few pictures:
Disclaimer:
I am from Michigan. I love the state and wish to move back there soon. My first REAL bushcrafting knife of good quality was a BRKT Aurora that I ordered from Crystal Falls Michigan (With matching custom Firesteel thank you very much) and I loved that damned knife. I have a soft spot in my heart for BRKT - they are 'local business' to me in a way.
With that said - I have owned quite a few Bark Rivers in my time and I have no issue with selling one that does not fit me - or calling BRKT to get something fixed or adjusted if I don't think it is perfect.
I have owned:
Aurora
3 Gunny's
A KF Forum Knife
Kephart
Kephart Companion
Ultra Light Bushcrafter
Liten Bror
Mikro Canadian II
Mikro Tusk
and a few others I am sure I am forgetting right now.
Specs:
OAL: 8.505
Blade Length (from handle): 3.725
Edge Length: 3.681
Blade Thickness: 0.153
Blade Height: 0.892 at rear of blade
Steel Type: A2
Handle Length: 4.589
Handle Thickness at butt: 0.911
Handle Thickness at Pinky: 0.775
Handle Thickness in middle: 0.964
Handle Thickness at front finger: 0.736
Handle Thickness at Ricossa: 1.076
Handle Width: About 0.800
Handle Material: Olive Green and Blade Micarta (Two different knives.
Pins and lanyard Tube: Stainless Steel
Packaging:
Bark River ships their knives in small rectagonal boxes, sheathes the blade in a cardboard cover, wraps the knife in tissue paper and plastic and sends the accompanying sheath in a separate plastic pouch. I have yet to receive a BRKT with any trouble in shipping. I bought this knife 'used' (very lightly - honestly - I couldn't even tell) and it came wrapped very similarly to the factory. No damage - the blade looks great.
This picture is borrowed from the Austalian Blade Forums site to show how a Bark River typically comes
Fit and Finish:
I talked to Jackie at BRKT a while back (I had sent a Gunny in to get the thumb ramp taken off) and I asked them not to touch the blade grind in any other way. It came back with the grind touched up and the etching put back on. When I asked why - she said they had changed policies lately on how they were sending out their blades and all blades that come in for spa treatment get this upgrade.
I didn't really think about it too much at the time - but now that I recall all the Bark River's I have owned - I think BRKT has made some improvements to their Quality Control in the last steps in blade finish, polish, and consistency.
The first generation Gunny's that I have owned were from the previous methods of grinding and polishing and could leave the blade a little rough in some areas. I was very happy to have the Spa treatment done on this knife when I sent it in to get the thumb ramp taken off (15 dollars - mostly just to pay for shipping) and see how even, smooth, and matte their finish now is. They put the original etching back on the knife and sent it back to me in factory condition - despite it being used for some time.
The handle is very smooth and the pins blend seemlessly into the Micarta. I find very very little wrong with this knife (there is one small misque in the butt of the knife - but you have to have hawk eyes to find it). I think BRKT is really stepping up their fit and finish and trying to repair any blade that comes into their shop for Spa treatment.
First Sharpening:
If you have read my other reviews you can see how anal I am when it comes to sharpening my knives and making them as perfect as I like them before using them. I might give an out of the box knife a text swipe or three at some wood or paper - but I usually break out the stones first thing.
This Gunny was no exception. I got out my Japanese water stones and made the bevel in a manner that I liked it. This is not to say that the knife didn't come well convexed and sharp. I am just anal. Anyway, I took a little material off the front of the knife (where the blade sweeps up to meet the tip) as I thought the convexing there was a little thick and I evened out and thinned out the convex grind toward the edge to make it move more smoothly from the saber grind to the edge.
I then moved to the Wet Dry sand paper, cleaned up any markes that were left from the stones that were not even and matched the matte finish of the blade from the factory by carefully running some wet/dry in a perpendicular manner to the edge. Once this was done, I carefully used wet dry up to worn 2000 grit and moved to a JRE Strop Bat and through three compounds and ended up on bare leather.
The A2 is very easy to sharpen, getting and holding an edge with ease. I find that worn 2000 grint on any semi firm background will make an edge perfect after a long day with these knives.
Blade Geometry:
The spine of the blade slopes every so slightly down from the mid point of the knife and then has the slightest drop point. It is a VERY high sabre ground full convex grind. The blade moves flat along the majority of its length sweeping up to the tip and creating a little belly. Due to the thickness of the steel the convex grind is steeper than some - but by no means too steep. It is a very robust edge designed for hard work and although it may sacrifice a little ease in slicing - it makes up for it by being strong and capable of other feats that a thinner steel may not be up to.
One thing that potential users should note is that the blade is fairly thin in terms of height from edge to spine. This blade is not the widest blade in the world (under an inch) and when choking up a person can run out of real estate pretty quickly. However, due to the overall design of this knife - this width fits this knife.
Balance:
The balance of this knife is right at the back portion of the front pin and right behind where your front finger falls naturally on the blade. It is slightly butt heavy - but not so much as to hinder performance and I didn't even realize it was this way until doing this review.
In Hand / Handle Design:
The handle design has always been a little bit of a conundrum to me as I prefer a more neutral handle and the Gunny is fairly contoured. However, where Mike excelled in this handle design was by carefully rounding off all the corners of the contours and the result is a very comfortable blade. Being contoured however, it favors the hammer and reverse grip - but can easily be pressed into service choking up, in the chest lever, and other positions.
This handle design makes sense as this knife was not made to be a Bushcrafter - it was meant to be issued to Military personel as a smaller option to the Bravo 1. However, Mike made this knife with some thought - and thus it can be easily used in bushcrafting. I really like the thought behind this blade design.
I will say this though. If you have a large hand the gunny may be on the tad small side for you. I wear size L gloves and find that it is one of my smaller handles in my hand. However, for some reason this doesn't seem to bother me like other knives have. I find it nimble and nice to use.
Sheath Shots:
The sheath that came with both of my Bark River Gunny's were the Sharpshooter Sur-Loc leather sheath.
Over time I made a sheath for this blade - here was my original one when I was fairly new to leather bending.
After a few years I made this sheath for my second knife:
Overall feelings after nearly a year:
I have come to love this blade. I will not be without a Gunny in my lineup for some time. It simply works. This review has almost seemed lackluster but this is because the knife does what I want it to do when I want it to. It is nimble and could be used for a myriad of projects, whether in the field or bushcrafting. This is absolutely one of my favorite knives - especially from Bark River.
TF
I've often lusted after a rampless Gunny. Thanks for adding to it with your review!
your killing the reviews lately sir. nice stuff. I have a rampless bravo1 and it's a great blade. keep them coming sir.
Thank you for the review! I wanted to get a Bark River for a long time. Though I really prefer smaller knives ... this seems to be a really handy and great knife. Maybe I´ll get one, maybe not...
Great review!
Kind regards
Another great review. going to send mine in to get the ramp ground off.
I had a spearpoint Bravo and it was more like a bulletpoint than a spearpoint. It was rampless, I loved it, and I sold it. I also had a rampless Gunny in A2 steel and matte black canvas micarta handles. I loved it, and I sold that too.
BRK knives are awesome and I agree with the OP... I have sent a few back to them to fix imperfections (usually caused by my own stupidity) and have sold pretty much all of them. I think the rampless Gunny is the one I probably miss the most.
Oh yeah, you can also get these in 3V now...
It took me almost a year and a half but I picked one of these up. I'm really diggin it. My first A2 steel knife. I'm taking this one hunting in a few weeks. This and hopefully a few others will get a workout.
Excellent review, and I'll second that the Bark River Gunny is a superb knife. I also have a rampless Gunny 3V (Orange G-10/Black Liners handle), and just bought a Gunny Hunter (Black Micarta/Red Liners handle).
Top: Bravo 1 CPM154 (Hard Rock Maple handle)
Middle: Gunny 3V (Orange G-10/Black Liners handle)
Bottom: Bravo Necker 3V (Orange G-10 handle)
Not wanting to change the topic from the Gunny, the picture of the Bravo 2 (African Blackwood handle) is the one I sold last year. I'm actually flattered you've used my photo. It was bought new from KSF, oiled and stored until I sold it. I found the Bravo 2 a bit too long for practical outdoor use, but the Bravo 1.5 is nearly perfect for outdoor/survival use in my opinion.
Fine review of a great, versatile knife, TF. Great work on that second dangler sheath as well!
After using both for a while, what's your preference between the Gunny and the Bushcrafter?
I have a normal ramped gunny, with black micarta handle and "bloody basin" spacers with mosaic pins
A nice solid working knife, that looks damn good too
Some knives you just develop an instant connection with, and I knew it from the moment I wrapped my hand around this Gunny. The model I chose has a mild drop point to it (slightly more so than the standard Gunny) which I feel makes it a little more of an all-arounder for my needs. This is not, however, the 'Gunny Hunter' model, which has a sabre grind and is only offered in CPM-3V at this time.
I really like this sheath. It doesn't ride too high, nor too low, its really well made, and it does a great job of securing the knife.
To answer my own question above in regards to a comparison with the BR Bushcrafter which I've had for a while now and enjoyed, the most obvious difference is, of course, the grind. I'm not going to dwell on the advantages/disadvantages of a scandi/vex vs full flat, which has already been discussed to death. Both grinds, in my opinion, will do a fine job with just about any bushcraft task, and it really comes down to preference and spending time getting familiar with it. I tend to prefer a full convex grind - 'nuff said.
The Bushcrafter (on top) is slightly longer that the Gunny, with a little more blade depth. The Gunny has a slightly thicker spine (.154" vs. .145") in A-2 steel, vs. the Bushcrafter's CPM-3V:
While these knives seem really similar in many ways, there are notable differences in ergonomics. There are objective factors to knife design for a given purpose, but when it comes down to ergs, a lot of it in my opinion is like asking for a recommendation on hiking boots - there are lots of good options, but at the end of the day, you just really need to try them and see what fits you best, so take my personal preferences in that context. I have med/large hands, and the Bushcrafter fills my hand notably more so than the Gunny. It just feels like a beefier knife all around.
The Gunny (on the left) has a more slender, but more contoured handle (both in width and depth):
Still, the Gunny gives me ample handle to work with, and doesn't feel too short at all. There are good contoured handles, and bad contoured handles, but Bark River gets it right in my opinion. There is enough contour for comfort, and to be able to 'index' your hand on knife, but the contours do not get in the way at all, and the knife is still very comfortable in just about any grip I would be using. Hammer, reverse, pinch, thumb on the spine - I find them all to be very comfortable with this knife (and with the Bushcrafter as well, just more so with the Gunny).
Even holding the knife with the edge facing up, as you might for some dressing & slicing tasks, I find that my thumb 'locks in' perfectly to the finger groove for a very secure grip:
I've been a Bark River fan for quite a while now, but it's taken me a while to get around to the Gunny. Not sure why, but it just never jumped out at me in the past. Sometimes you need to get a knife in hand in order to appreciate its virtues, and now I understand why it's been such a favorite for so many. The bottom line for me is that the knife that feels 'beefier' isn't always what I gravitate toward. The Gunny feels lighter and more nimble in my hand, without sacrificing any usability for serious work. Short of big chopping (which I don't tend to use a knife for anyway), there isn't much the Gunny won't handle.
All in all, from having my 'ideal' blade length, to the excellent handle, right down to the sheath, the Gunny hits all the right notes. I can't believe I've waited this long to get one. I'm confident we'll be spending a lot more time together...
Man, I should pick another one up again, it definitely was one of those I really regretted selling.
