Bark River Gunny REVIEW!
When it comes to utility EDC knives, there is a vast and seemingly endless amount of designs and styles out there, that one could easily become overwhelmed with when trying to choose one. There are certain characteristics that most people look for however. Comfort, style, adequate size, unobtrusive carry, durability and so on. Interpretations of these qualities in knife makers are as vast as the opinions out there. Many fall short, others do not. This brings me to the Bark River Gunny.
I think it is safe to assume that if an EDC style knife is worthy of taking the time to do a review, there are certain aspects in every day life that really do not need to be elaborated on. Cutting up a cardboard box and slicing up an apple is something that is expected. Where I want to focus on is how well this "small in stature" knife excels at the bigger things in life. This brings me to my familiar playground on the Wisconsin River in the northwoods of Wisconsin.
The Gunny is an ergonomically friendly knife, well suited for a variety of grip choices and comfortable in nearly any hand size. I have fairly large hands and the Gunny fills my palm very comfortably and easily with some room to spare for the super sized paws out there. This knife was designed with extended use in mind. it is very apparent. At 8.4" in total length with a 3.775" blade, you can see how the proportions are designed to accommodate both decent size in blade and handle. In a package that weighs slightly more than 5 1/2 ounces, it has the ability to fill a vast array of roles. I am also of the opinion that it is a GOOD looking knife as well.
Comparing the Gunny to it's larger brothers in the family, you will see it is nothing more than a scaled down version of the Bark River Bravo-1. While it does not look like it is a sizable ratio by which it was minimized, the Gunny is as different from the Bravo-1 as the Bravo-1 is from the larger Bravo-2. An easy way to put this in relation is to take a baseball bat or steering wheel. The difference in feel when you put either tape around the bat handle or a wrap on the steering wheel is very substantial, while not really being much different in size. Hands easily recognize small variations in size. The relation this same principle carries over from the Bravo-1 to the Gunny is no different, other than to say they are VERY different knives.
Carrying the Gunny in the supplied Sharpshooter Sur-Lok sheath is pleasant as well. The knife rides tight and slightly higher. The higher carry allows a good compromise for body movement, extraction from the sheath and sitting positions. We all know what a pain it is to have a low-riding dangler sheath that we have to constantly adjust while in the truck or dining at a restaurant. The sheath eliminates much of that while still providing excellent retention thanks to a cam action locking design. The design of the Gunny had a strong focus on EDC. This knife fills that bill quite well.
Ok, now that we have discussed the carry aspects, simply having a knife with you does not mean that you have a tool that is worth a darn. Since I already had a fire going, I was running out of wood and this seemed like a perfect start to testing out the Gunny by splitting up some wood.
The Gunny is made out of A2 tool steel with a very proprietary heat treat from Bark River. This heat treat lends excellent toughness, while maintaining great edge holding characteristics and still providing ease of sharpening. The Gunny has a moderate convex profile to it which works well in heavy tasks. Batoning through white oak is easy, as to be expected, but going through knots in seasoned and older hardwood is a different story. Many knives would roll or distort an edge doing just this. Not the Gunny. As you see, I purposely drove that edge through a knot to demonstrate not only the toughness of the steel, but the strength in the edge.
I want to make this perfectly clear, that you have a knife with you for a reason. That is why you baton all the way through a piece of wood, instead of getting most the way through and then prying it apart with your hands. Something like this will happen otherwise. That splinter did smart a bit...more so pulling it out. :D
Cross grain batoning is also another task that the Gunny excels at. Pictured is Ironwood. Notice how deep I could drive that knife on the initial cut. This knife chews through wood very easily.
Draw cutting and removing bark is very easy as well. I think this demonstrates the ability of the Gunny to slice. I made a walking/hiking stick out of aged Ironwood. While the Gunny had no part in the sanding or staining, it took care of all the heavy work without complaint. Remember when I mentioned ergonomics? This knife excels at extended use...better than most other knives I have put in my hands. Hot spots are eliminated thanks to a well sculpted and non-faceted handle design.
Whittling and carving is effortless with the Gunny. You actually have to be careful because it is too easy to bite off more than you want to. Making up tent stakes takes only a couple minutes and should you ever be put into such a precarious position where you needed to make a fishing spear, it does that as well. :D
All in all, and as much as I hate to say it, the Gunny can single-handedly make extinct a whole line of knives from many different knife makers.
It has been said that "You only know the value of a knife if you use it". In this regard, the Gunny may as well carry all the weight of Fort Knox on it.
As of the date of this review, Derrick and Wendy at www.knivesshipfree.com have 31 Gunny's in stock with equally as many handle choices to choose from. Swing on over and see what suits your tastes best.
Nice review:thumbup: What handle material is that? I really like the color!
That handle is in Forest Green G-10. It is a handle material that has been making steady improvements in popularity for Bark River. :thumbup:
Great review. I have been thinking of a Bravo-1 but now I might have to get a Gunny instead. do you find it more useful than the bravo-1?
Actually, yes I do. There are few things the Bravo-1 can do more so than the Gunny. Matter of fact, there is only a 1/2" or so blade length difference. The Gunny is lighter and more compact. For those that prefer a large grip, the Bravo-1 beats the Gunny but the Gunny is not small by any means.
I want to mention that all images can be enlarged by clicking on them for better detail.
Great review! This is the first in depth review I have seen on the Gunny. I am going to have to pick one up. It looks great. Thanks for the review.
It's a really great knife. I'm partial to rampless variety, it looks completely different. I'll have to snap a picture of mine sometime.
Yes, that is a great looking variant of the Gunny...the rampless version.
As for this being the first in depth Gunny review, it was suppose to be up 3 weeks ago. :D
Nice review and pics. I liked everything about my Gunny except the ramp, so off it came. Funny, because I don't mind the ramp on my Bravo-1 at all. The rampless Gunny feels much better now. I still prefer the B-1, but the Gunny isn't far behind.
Wanna know what rocks about what you said bro? The fact that such a small variant is what makes the world go round. It never ceases to amaze me that there is so much 'individuality" amongst a common interest. :)
I do want to mention that if a Gunny is not a good fit because of the ramp, Bark River will take it off for the price of shipping. Pretty cool little bit of customer service if I do say.
Great review :thumbup: I have my Gunny w/o the ramp on the way from KSF (thanks again Derrick) :D I believe my knife search might stop for a long while :) Between my NWA Sierra Scout, SS Bravo-1, and my new Gunny...I foresee contentment for quite a while. And a reprieve for my wallet...
Oh wait...I still need a golok....:D
So true:) Here is mine, sweet looking without the ramp.
Nice job on the review Jeff. :thumbup: :cool: :thumbup:
The Gunny is truly a “contender” as one of the best.
I will say again that I think this is one will give the Bravo-1 a run for the money as Bark River’s best seller.
:p :eek: :p
FWIW, I would like to see a Bravo-1 style knife with the thinner blade steel of the Gunny, push the blade length to 5” and eliminate the thumb ramp and you might just have the perfect belt knife for field use.
Just one knife users opinion, :D YMMV.
Big Mike
”Scaring the tree huggers.”
Forest & Stream
That is the EXACT blade I would like to see Big Mike :thumbup:. Exactly the idea I had in mind too.
